Intermittent Heater Problems (no Heat) - BMW Forum - BimmerWerkz.com
Old 01-17-2005, 03:50 PM   #1 (permalink)
openclassrally is an unknown quantity at this point
Guys,
my friends 318ti seems to be having random heater issues.... It seems that the heat is not working all the time but the blower seems to be...... I have yet to check the thermostat or anything else for her, but just wanted to see if there are any common problems with these cars?????
Also it does NOT overheat or run HOT..........
Cheers
Larry
#622 SCCA open class rally
openclassrally is offline   Reply With Quote
Old 01-18-2005, 04:57 PM   #2 (permalink)
Car: 1993 325i
victorgallas is an unknown quantity at this point
Send a message via ICQ to victorgallas Send a message via AIM to victorgallas Send a message via MSN to victorgallas
Originally posted by openclassrally@Jan 17 2005, 04:50 PM
Guys,
Cheers
Larry
[snapback]273498[/snapback]
IF blower works, then check the heater valve, is on engine compartment right next to the brake booster on the firewall, youll see a three wires attaching to il and three blck hoses. one for intake, other two go inside of car.. normally this valve gets stuck, but ill you try to pull out the wire plug from the valve, cleaned and plug it back in see if it works, if not, try then tapping th etop of the valve with a metal, not so hard, you dont want to bend it, but just enought to make it unstick, with is what happens, the center parts sticks after some time. Dont forget to do this then the heater is set to full hot, so you make sure its sending power to open the valves.
IF nothing works, then go on ebay buy one an they replace it, just unbolt the onther one, put the new one it and bleed the coolant.
You are a BMW driver when you become part of the "Ultimate Driving Machine"
Fraude an Fahren
BMW > Bayerische Motorenwerke
Auf Viedersehen der herr
www.clemsonfsae.com
victorgallas is offline   Reply With Quote
Old 01-21-2005, 12:49 PM   #3 (permalink)
Thanks for the info.... I will take a peek tommorow......
Cheers
Larry
#622 SCCA/RALLY AMERICA
Old 01-21-2005, 04:26 PM   #4 (permalink)
Darkmage is an unknown quantity at this point
Cheers
Larry
[snapback]276153[/snapback]
Does this car warm up all the way? If he goes on the highway does the engine get colder?
If yes, I would guess it's a thermostat problem. (I have the same problem right now)
Although after I leave it running it does seem to blow somewhat warm air, and the temp is right outside the blue range
<img src='http://uploads.blizzpub.net/uploads/darkmage._SIG.jpg' border='0' alt='user posted image' />
Darkmage is offline   Reply With Quote
Old 01-21-2005, 04:57 PM   #5 (permalink)
docrobot's Avatar
docrobot is an unknown quantity at this point
A simple problem to no heat is not enough Fluid. Check the level of fluid in the Rad...
docrobot is offline   Reply With Quote
Old 01-21-2005, 10:14 PM   #6 (permalink)
spieluhr's Avatar
spieluhr is an unknown quantity at this point
Send a message via AIM to spieluhr
my heater only worked after i floored it or if i was overheating. The problem was my water pump, the pump was probably about to go and it was too weak to move enough fluid over the heater core to get heat into the car. This wasn't a very expensive procedure and worked for me, might want to check it out.
btw, i feel your pain, not having heat for like 2-3 months in the fall and winter SUCKS!
<img src='http://img268.echo.cx/img268/1430/zkwsig23iq.jpg' border='0' alt='user posted image' />
1996 328is Black
Suspension: MB Motoring 18x8, Kuhmo Supra 225/35/18ZR
Audio:Eclipse CD3414 HU
Lighting: ZKW W/ DDE PLUS
spieluhr is offline   Reply With Quote
Old 01-21-2005, 10:23 PM   #7 (permalink)
motown3's Avatar
motown3 is an unknown quantity at this point
Guys,
Cheers
Larry
If you are not getting heat when idleing but get heat when you are keeping the RPM above 1800-2000 and or when you are moving, it is the heater control valve. This is an easy fix. About 70-80 bucks for the valve and about 30-40 minutes to change out. If you clamp off the hoses, you can change without messing without draining out hardly any antifreeze. Once it has been changed you will need to "burp" the lines before your heat will work (cycle the temp where the thermistat opens, then top off). Good luck!
&quot;Friends may come and go, but enemies accumulate&quot;
motown3 is offline   Reply With Quote
E39 Heater Problems Vez 5-Series (E12,E28, E34, E39, E60) 4 10-20-2009 01:04 AM
Heater Problems DKMassive 5-Series (E12,E28, E34, E39, E60) 0 07-06-2005 10:07 PM
Radiator / Heater / Ac / Control Knob Problems badmo 3-Series (E36) 0 05-01-2005 06:53 PM
Heater Core Problems? emmceethree 3-Series (E21, E30) 0 01-13-2005 12:46 PM
733i no heat or heater operation vengeance105 1,6,7,8 - Series and Mini Cooper 0 01-27-2004 07:59 PM
