Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 12-28-2004, 02:46 AM   #1 (permalink)
own
Photos: 0
own is an unknown quantity at this point
HELLO TO ALL I HAVE AN EURO E36 ITS A BMW 325 TD (TURBO DIESEL)
AND THE INSTROMENT PANEL (dash lights),AC,WINDOW SWITCHS,ETC DONT LIGHT UP.
I HAVE CHECKED FUSES AND THEY SEEM OK . PLEASE CAN ANYONE HELP WITH THIS PROBLEM. THANKS IN ADVANCE
own is offline   Reply With Quote
Old 12-29-2004, 06:28 PM   #2 (permalink)
kestrel325is's Avatar
Car: 1995 325is 5-speed
Photos: 0
kestrel325is is an unknown quantity at this point
[snapback]259427[/snapback]
Have you checked the dimmer switch? Does it get hot when you turn on the headlights?
There should be 3 wires leading to the switch: grey/red , grey/black , and brown.
The brown's the ground, and the grey/black is the 12v feed from the headlight switch. Check it to see if the switch (grey / black) is getting power when you turn on the headlights. Then check to see if the grey/red wire is getting power. After the switch, the grey/red wire should have about 10v with the switch turned all the way up.
Hope this helps somewhat!
<img src='http://oregonstate.edu/~westerc/youarenot.gif' border='0' alt='user posted image' />
&quot;You haven't showered in two days and you're covered in botulism. You aren't exactly a desireable being right now.&quot; -- my fiance
kestrel325is is offline   Reply With Quote
Old 12-30-2004, 08:37 PM   #3 (permalink)
own
Photos: 0
Originally posted by kestrel325is+Dec 29 2004, 11:28 PM--><div class='quotetop'>QUOTE(kestrel325is @ Dec 29 2004, 11:28 PM)</div><div class='quotemain'><!--QuoteBegin-own@Dec 27 2004, 11:46 PM
* I HAVE CHECKED FUSES AND THEY SEEM OK . PLEASE CAN ANYONE HELP WITH THIS PROBLEM.* * * * * * THANKS IN ADVANCE
[snapback]260520[/snapback]
[/b][/quote]
THANKS WILL TRY AND POST THE RESULTS
Old 01-04-2005, 05:56 PM   #4 (permalink)
Photos: 0
Originally posted by own+Dec 30 2004, 05:37 PM--><div class='quotetop'>QUOTE(own @ Dec 30 2004, 05:37 PM)</div><div class='quotemain'>
Originally posted by kestrel325is@Dec 29 2004, 11:28 PM
<!--QuoteBegin-own
[snapback]261379[/snapback]
[/b][/quote]
Any luck?
Old 01-05-2005, 05:14 PM   #5 (permalink)
Photos: 0
frank3 is an unknown quantity at this point
while you're at it, check for any blown fuses.
<span style='color:green'>1994 325i </span>- - - 75,000 mi.
No mods - - - very happy as is!
<span style='color:green'>1995 525i </span>- - - 154,000 mi.
No squeaks or rattles... unreal!
frank3 is offline   Reply With Quote
Old 01-05-2005, 08:25 PM   #6 (permalink)
RIBEMR26's Avatar
Photos: 0
Why didn't HE check that....oh yeah....he did.....
Clear Corners and Sidemarkers
Old 01-06-2005, 12:07 PM   #7 (permalink)
Photos: 0
[snapback]265113[/snapback]
OOPS! Sorry about that!
Old 01-10-2005, 01:35 AM   #8 (permalink)
own
Photos: 0
hey guys whats up . i started by cheking all the lights and on the climate control
i found one that was blown . a friend from work said that the interior light system works more or less like the christmas tree lights(one gos out then lots others go with it).i havent got around to the headlight switch yet because i want to replace the blown light bulbto see if that solves it.any other sugestions are welcome. thanks to all of you for the effort.
Old 01-20-2005, 12:01 PM   #9 (permalink)
Car: 1993 325i
Photos: 0
victorgallas is an unknown quantity at this point
Send a message via ICQ to victorgallas Send a message via AIM to victorgallas Send a message via MSN to victorgallas
interior lights do not work like christmas trees, of one goes out, is just that one is out. thats it. what happens is that once they get old, like some good 8 years or so they become weak and easy to burning..
anyway,.
first make sure your dimmer on the dash is all the way and that it is giving an output just like described on the first response.
also check input..
the dimmer is the most likely cause of this problem.
but there is another thing also.
im not sure about if there are relays to activate the interior panel lights, i doubt it.
if needed look on google.
but what could have happened it that the clarity sensor on the dashboard when nuts, or the wire on the rear of the speedomeder got loose..
have you ever noticed a little white round thing at the end on the speed indicator. it look like a light bulb, but is not. is a ambient light sensor, this tells the dashboard how bright it is inside the car, so it automatically dims the speedometer mileage display and the obc display up or down according to clarity, the system only works when the lights are off, since its day. and during the day we go trought tunnels, some dark, or very bright spots/./ so the car adjusts the brightes of the lcd display to be visible during the day with different clarity.
think this is not true, get in your car, start it, with the lights off. get a flashlight righ on top of the white thing. wach the speedometer display and obc display dim up.
then put your finger. and wach it going down./ But this change is not instant, you have to maintain the light, or your finger there for a couple of secs, and even then the dimming process is very sloww. look carefully.
going back to subject here. test the dimmer swicht first, make sure its getting power and that it is sending it out.
let us know if that helps.
You are a BMW driver when you become part of the &quot;Ultimate Driving Machine&quot;
Fraude an Fahren
BMW &gt; Bayerische Motorenwerke
Auf Viedersehen der herr
www.clemsonfsae.com
victorgallas is offline   Reply With Quote
vB code is On
Fog Lights... 4evrwyntr M-Series (M3, M5, M6) 9 03-23-2005 11:04 PM
Side Lights storme 3-Series (E46, E90) 2 03-08-2005 01:14 PM
For Sale: E46 Lights scrantonml Classifieds Sell & Buy 0 01-28-2005 12:15 PM
Group Buy on e36 Euro crystal clear tail lights calm3 Classifieds Sell & Buy 13 04-26-2003 06:56 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
