Interesting Heater Behavior - BMW Forum - BimmerWerkz.com
Old 11-01-2004, 08:50 PM   #1 (permalink)
hockey_fan's Avatar
hockey_fan is an unknown quantity at this point
Hey guys,
Strange heater problems. 96 328is
The heater doesn't blow any hot air, just keeps blowing cold on any setting.
However, if I turn on the front defrost button the heat blows fine.
I just had the thermostat replaced a week ago and today was the first time I tried to use the heater.
Thanks for your help.
hockey_fan is offline   Reply With Quote
Old 11-01-2004, 08:55 PM   #2 (permalink)
Deloriant's Avatar
Deloriant is an unknown quantity at this point
Send a message via AIM to Deloriant
Sorry, not sure what it is, but I just dropped in to say 96' 328's rule! WOo!
<img src='http://i116.photobucket.com/albums/o17/M4yorThis/119575444991686.jpg'>
Deloriant is offline   Reply With Quote
Old 11-01-2004, 09:59 PM   #3 (permalink)
RallyE36 is an unknown quantity at this point
If you have the automatic climate control (11 button) dash unit, you could have one of these 2 problems:
1- The final stage resistor is gone ($127 CDN)
2- The climate control unit is starting to fail ($400CDN)
1996 E36 M44 318i 5sp LSD
Canadian Model
RallyE36 is offline   Reply With Quote
Old 11-02-2004, 12:51 PM   #4 (permalink)
2.link's Avatar
2.link is an unknown quantity at this point
Send a message via AIM to 2.link
your coolant system is most likely low on coolant, leaving air pockets in your system will cause the heater not to work. Check your coolant level before you go and start replacing things.
<img src='http://www.european-forums.com/forums/uploads/post-1-1107198379.jpg' border='0' alt='user posted image' />
Formally known as Asio.
2.link is offline   Reply With Quote
Old 11-02-2004, 01:35 PM   #5 (permalink)
pcy
pcy is an unknown quantity at this point
Originally posted by hockey_fan@Nov 1 2004, 09:50 PM
Hey guys,
[snapback]222659[/snapback]
Right above the heater vents (on the center console), look closely,
it you turn the dial to the right (I think), you will get hot air.
I had the similar problem recently; After trying bunch of things,
I realized the dial was set to "blue" or Cold. My daughter must've
messed with it. Take a look at that vent setting.
If that vent dial is set correctly, then follow others' suggestions.
Good Luck.
pcy is offline   Reply With Quote
Old 11-02-2004, 10:01 PM   #6 (permalink)
hockey_fan's Avatar
Originally posted by pcy+Nov 2 2004, 01:35 PM--><div class='quotetop'>QUOTE(pcy @ Nov 2 2004, 01:35 PM)</div><div class='quotemain'><!--QuoteBegin-hockey_fan@Nov 1 2004, 09:50 PM
Hey guys,
Good Luck.
[snapback]223080[/snapback]
[/b][/quote]
Thanks guys,
I will give these things a shot. Hopefully one of them will work.
Old 11-03-2004, 11:24 PM   #7 (permalink)
spieluhr's Avatar
spieluhr is an unknown quantity at this point
Send a message via AIM to spieluhr
im having the same damn problem, and in the winter it really sucks ass havign a cold car, aside from my toasty butt warmers. it blows hot once in a while when i am on the high way traveling at high speed, if i play with teh temp. setting a little (jog it back and forth).
<img src='http://img268.echo.cx/img268/1430/zkwsig23iq.jpg' border='0' alt='user posted image' />
1996 328is Black
Suspension: MB Motoring 18x8, Kuhmo Supra 225/35/18ZR
Audio:Eclipse CD3414 HU
Lighting: ZKW W/ DDE PLUS
spieluhr is offline   Reply With Quote
Heater Problems DKMassive 5-Series (E12,E28, E34, E39, E60) 0 07-06-2005 10:07 PM
Heater Problem Bmmf40 5-Series (E12,E28, E34, E39, E60) 1 07-03-2005 11:38 PM
Heater Core ? walshja 3-Series (E36) 8 01-19-2005 05:39 PM
Analog to Digital Heater Conversion Digital318is 3-Series (E36) 3 04-02-2004 01:34 AM
Engine Overheating/Cold air from Heater Bluebonnet 5-Series (E12,E28, E34, E39, E60) 6 12-17-2003 06:41 PM
