**Instant Help Required** - 318i Power Issues - BMW Forum - BimmerWerkz.com
Old 07-02-2006, 10:23 AM   #1 (permalink)
mmclaren is an unknown quantity at this point
Exclamation **Instant Help Required** - 318i Power Issues
Yestrerday, driving after 1000km, lights dimmed, airbag light came up, ABS light flashed, after 10mins the problem went away.
Now tonight battery idicator light showing on cluster.
Not enough power to crank engine.
Replaced battery, battery light still showing, when reving over 4k battery light slowly dims and disappears after 5k RPM.
Is my Altinator gone???
Please Help ASAP.
Thanks.
mmclaren is offline   Reply With Quote
Old 07-02-2006, 12:04 PM   #2 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Your alternator is most likely dying or, from the sound of it, is an ex-alternator.
Lindsay fan club member.
Old 07-02-2006, 12:28 PM   #3 (permalink)
RexKing86's Avatar
Car: 2006 Mitsubishi Lancer Evolution MR
RexKing86 is an unknown quantity at this point
Send a message via AIM to RexKing86
alternator...
RexKing86 is offline   Reply With Quote
Old 07-02-2006, 02:38 PM   #4 (permalink)
thekid's Avatar
^^ sounds like the culprit. Get a volt reader and check the voltage that the alternator is putting out. This will tell you for sure. I was able to pick a digital one up for less than $20, it is a handy thing to have around.
Old 07-02-2006, 05:16 PM   #5 (permalink)
Woek up this morning, and drove it to work, the battery light wasn't showing until after 5 k where it became dim.
Ill try getting hold of a new alternator today.
Is it a possible DIY job?
Old 07-02-2006, 08:41 PM   #6 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
just download the bentley... you can replace it easily...
Old 07-03-2006, 01:29 AM   #7 (permalink)
Sent it into the stealership
Dont have any tools where i am atm.
Also Bought another BMW 320i
42,000 K's on it
Not registerable in Australia lmao, unless i take it through a heap of engineer reports.
Plan is to Strip the interior, and make a off road rally car.
Problem is its an auto, which in some ways could be better :P
Thanks for everyones input, i did go with the new alternator ($448au) took it in today, they will try and squeeze the job in, advising 1 hour labour
Old 07-03-2006, 12:41 PM   #8 (permalink)
Car: 1997 DINAN 328i
SOLO5977 is on a distinguished road
Deifinatly the alt...
SOLO5977 is offline   Reply With Quote
Old 07-05-2006, 02:08 PM   #9 (permalink)
Redbullrr's Avatar
Redbullrr is on a distinguished road
Had the same problem turned out to be the Altenator.
Redbullrr is offline   Reply With Quote
Old 07-05-2006, 04:55 PM   #10 (permalink)
ex owner/admin
Furious's Avatar
Please Help ASAP.
Thanks.
yes the alternator is gone, the reason the abs light and airbag goes on is because its a failsafe that all cars have when they sense a problem with the charging system. the battery light indicates and solidifies that your problem with the charging system is gonna more than likely gonna be your alternator.
Old 07-05-2006, 10:12 PM   #11 (permalink)
Yeah thanks for everything
Alternator has been replaced and is now running great
Does An '85 318i Have Power Steering? dsio 3-Series (E21, E30) 1 03-31-2005 09:32 AM
Best Kind Of Headlight Bulb? all4isu 5-Series (E12,E28, E34, E39, E60) 6 10-18-2004 02:26 PM
No power to Stereo 318i '97 MattR Audio and Electronics 4 07-25-2004 01:07 AM
power pulleys, re they really that bad? the///man 3-Series (E36) 1 10-18-2003 09:12 AM
