| The part that holds the grills in place is slightly bent. Assuming I need to replace this piece how do you get at the bolts to remove/ install? Does the bumper need to be taken off to reveal the bolts or do you access them through under the hood?
Also the hood is pushed up about a quarter inch- just enough to make it so it isnt flush. If i were to replace the hood would the new one bolt on and perfectly line up? |
