Installed A High Flow Cat - BMW Forum - BimmerWerkz.com
Old 03-14-2005, 11:25 PM   #1 (permalink)
bluee36e36 is an unknown quantity at this point
i had a high flow catalytic converter on my 325is today and it makes a pinging sound from about 2000rpm up to about 3500 when the vanos kicks inn.
why does it do this? is it because i took off the resonators and will it go away if i use glasspacks as mufflers because they act as resonators?
bluee36e36 is offline   Reply With Quote
Old 03-15-2005, 02:19 PM   #2 (permalink)
i didn't install it myself, i had my mechanic install it and it took about an hour and a half
Old 03-15-2005, 02:41 PM   #3 (permalink)
The Deuce is an unknown quantity at this point
More exhaust flow = Leaner mix.
If you are too lean now you could be pinging in the motor which is detonation and a VERY big deal. You need to check the a/f and make sure this isn't the case. If it is and you don't take care of it right now you coudl grenade the motor.
2002 BMW 530i
1997 Ford Mustang GT
1995 Honda VFR 750 (For Sale)
1964.5 Ford Mustang
The Deuce is offline   Reply With Quote
Old 03-15-2005, 03:45 PM   #4 (permalink)
tomctx's Avatar
[snapback]311650[/snapback]
What year is your 325? My 95 has two cats. Did you replace two with one? Did you replace the whole center section? Pinging is usually a sign of leaness and detonation, not a good thing.
Old 03-15-2005, 04:15 PM   #5 (permalink)
i doubt just installing a high flow cat would make his car run lean or else this problem would occur 10,000 times a day on here, there has to be another explaination
Ireland Engineering High Flow Injectors egk2 3-Series (E21, E30) 4 06-06-2005 03:23 AM
Thermostat Installed Upside Down, Maybe? YoungExec728 3-Series (E36) 2 12-09-2004 03:15 PM
High Flow Cats?? Bimmin'88 3-Series (E21, E30) 8 10-18-2004 01:38 PM
FS: Kirban high flow intake E36 96+ Bimmer Classifieds Sell & Buy 2 05-20-2004 12:10 AM
Help on Air flow meter BmWNoobie 3-Series (E21, E30) 1 09-11-2003 04:04 PM
