Installation of Subs and Amps - BMW Forum - BimmerWerkz.com
Old 02-28-2009, 06:16 PM   #1 (permalink)
ian3's Avatar
ian3 is on a distinguished road
Hey my friend gave me a ten inch sub along with the amplifier. I just want a little more bass from the stock system. But I don't really know how to install the subwoofers and the amp through the stock unit. If someone could tell me directions or send a link on how to do this job that would be great.
Thanks,
Ian
///M
ian3 is offline   Reply With Quote
Old 02-28-2009, 06:35 PM   #2 (permalink)
vincentmb615's Avatar
Car: 94 325i two toned full body kit
vincentmb615 is on a distinguished road
Send a message via AIM to vincentmb615
you need a iec auloc which you bridge of the decklid speakers which is were your preouts come from the remote wire can go to the stock amp turn on ground in trunk and power to batt good luck
[94 325i two toned
vincentmb615 is offline   Reply With Quote
Old 02-28-2009, 08:44 PM   #3 (permalink)
ian3's Avatar
im confused....if you can or someone else can give me more specific instructions that 'd be good.
Thanks
///M
Old 02-28-2009, 08:51 PM   #4 (permalink)
ok a iec autoloc is a converter that converters speaker wire to rca outputs which will go to the rca input on the amp the instructions to install that come with it best buy has them you splice into speaker wire all you do is go in and say you want to install subs off the stock hu the rem which stands for remote goes on the amp and to a source that has 12 volts when the key is on the batt wire goes to the batt and ground goes to bare metal in the trunk
[94 325i two toned
Old 02-28-2009, 10:17 PM   #5 (permalink)
ian3's Avatar
I think they sell the iec autoloc converter at best buy. Is this it?
Scosche - 2-Channel Adjustable Line-Out Converter - Clear - LOC80
///M
Old 03-01-2009, 02:22 AM   #6 (permalink)
Mr. Clean
BimmerE39's Avatar
I'm going to be honest with this one here, the sub more than likely won't sound too good. IEC's make it work but tuning everything in gets kind of complicated and IMO not worth it. Late 90's early '00 sound systems in BMW's sucked. I had one in my car and it was horrid so I know your pain.
Old 03-01-2009, 12:08 PM   #7 (permalink)
ian3's Avatar
yea i think i am just going to leave my system stock until i can do it right because this seems a little cheap...i'd rather do it right...
Thanks for the help everyone,
Ian
///M
Old 03-02-2009, 02:23 AM   #8 (permalink)
garbone's Avatar
Car: 97 BMW M3, 93 Honda Del Sol 427hp
garbone is on a distinguished road
Send a message via Yahoo to garbone
does the amp have high level inputs? i ran my amp for off the stock wiring and stereo for a year. had no problem with the sound. i just spliced into the wiring coming off the stock head unit.
But i have since replace my head unit with one that has RCA outs.
Im not a fan of the stock head unit and the business model was out of my price range. bought a head unit with lights that matched the stock lights almost perfectly for 120 and the harness adapter for 12 and some change. works great.
garbone is offline   Reply With Quote
Old 03-02-2009, 07:19 PM   #9 (permalink)
i havent had issue with a autoloc at all i put one in a cadillac sts due to the fact the door chime was in the speaker and all the speakers had amps woah i will never put a hu in one of those things thats a mess thats why we settled on a autoloc and it sounds good now in my 325i i had to run 4 wires for the rear speakers because something got screwed up with the stock amp but it wasnt a big deal save your money but i havent had a issue wit one
[94 325i two toned
FS: 2 RF Subs and 2Audiobahn Amps ooibhuskyoo Audio/Miscellaneous Auto Parts 0 05-08-2006 01:30 PM
Wtb Broken Amps, Subs, Decks, Etc. tplaya07 Audio and Electronics 1 07-27-2005 06:22 PM
got a set of spkr, subs & amps... dfantom Audio and Electronics 0 08-19-2004 02:42 PM
battery cranking amps jason325i 3-Series (E36) 0 02-11-2004 04:57 PM
72 AMPs? 130,000 watts? Nine 15 inch subs? GreenDragon Audio and Electronics 8 07-26-2003 09:06 PM
