Install Help! - BMW Forum - BimmerWerkz.com
Old 08-31-2004, 07:26 PM   #1 (permalink)
uber e36's Avatar
uber e36 is an unknown quantity at this point
Send a message via MSN to uber e36
Gentlemen,
I just purchased a CAI (no name pipe with Dinan filter and water sleeve) and an Eibach front strut tower brace.
Questions:
1. Can I just undo the bolts at the top of the strut tower and install the brace as simply as that?
2. I believe I have to relocate one of the horns in order to have the CAI fit properly. Where do you relocate it to?
**EDIT
I found this link to be usefull for the horn relocation:
http://forums.bimmerforums.com/forum...d.php?t=229755
Thanks Guys!
Click signature for pictures:
Need some Real Estate Advice? www.gracehomes.com
uber e36 is offline   Reply With Quote
Old 08-31-2004, 09:19 PM   #2 (permalink)
Kevin325i's Avatar
Yes you can just take the nuts off.
BUT, if you don't use an impact wrench it will just spin underneath and the nut will not loosen. The only problem would be if you tried to undo the nuts while the front wheels were in the air, then the struts would fall out.
Kevin (President TBEA)
Old 08-31-2004, 10:16 PM   #3 (permalink)
uber e36's Avatar
Care to explain what an impact wrench does?
Old 08-31-2004, 11:32 PM   #4 (permalink)
Kevin325i's Avatar
Itstead of making a big twisting force on the nut, the impact wrench basically uses short pulses (impacts) to get the nut off.
See if you can get one of the techs to help you out at the dealer. It won't take but 30 minutes to install it, probably less.
Old 09-01-2004, 01:19 AM   #5 (permalink)
2.link's Avatar
2.link is an unknown quantity at this point
Send a message via AIM to 2.link
the strut bar goes on the bolts from the strut hat, not on the actuall rod in the strut. Kevin is talking about a different part. To install the strut brace you bought you will probably need to pick up a few washers, like 3 for each nut, you'll see why when you go to install it. All you do is take like a 12mm socket and a ratchet and take the nuts off, place the washers on the bolts that are pointing through and place the strut brace on, then put the nuts back onto the bolt and tighten them down.
<img src='http://www.european-forums.com/forums/uploads/post-1-1107198379.jpg' border='0' alt='user posted image' />
Formally known as Asio.
2.link is offline   Reply With Quote
Old 09-01-2004, 12:01 PM   #6 (permalink)
uber e36's Avatar
Are the washers used because the cruise control wire runs overtop of the left strut tower?
**ALSO
It appears that I have two horns behind my left headlight, do they both need to be moved?
Old 09-01-2004, 02:39 PM   #7 (permalink)
2.link's Avatar
Only one of the horns needs to be moved, and you will have to cut or bend the piece that held on that horn.
The strut car should have a dent cut out in it for the wires so that they do not cause an interference.
Help! :( Headlight Install miztuhdan 3-Series (E46, E90) 1 07-13-2005 07:23 AM
Ipod / Icelink Install W/ Photos - Concealed Ashtr WindowPro Audio and Electronics 0 12-29-2004 12:06 PM
Help! Chip Install Gone Bad. Brian325i 3-Series (E36) 11 10-03-2004 12:51 AM
Another E39 aftermarket H/U install.....SOS! Endangered Beatz Audio and Electronics 6 05-31-2004 10:26 PM
