Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 06-27-2004, 11:46 PM   #1 (permalink)
Kissner's Avatar
Car: 1998/BMW/M3
Photos: 0
Kissner is on a distinguished road
Send a message via Yahoo to Kissner
Is there any way to reset the inspection light in my M3? I know i can take it to a dealer, but it's gonna cost alot of money. Is there a reset tool that i can buy or anyway that i can reset it without takin it to a dealer? Thanks
Kissner is offline   Reply With Quote
Old 06-28-2004, 02:32 AM   #2 (permalink)
Defector
El Presidente's Avatar
Photos: 0
95 or 96+? Theres an FAQ for OBDI, but I don't think it works for OBDII.
Old 06-29-2004, 01:27 PM   #3 (permalink)
Kissner's Avatar
Car: 1998/BMW/M3
Photos: 0
1998 so it's got the OBDII. That's a bitch, i think i might just drive it with it on, it only shows up for 5 seconds everytime i start my car. Thanks
Old 06-29-2004, 01:41 PM   #4 (permalink)
Threadkiller
bitcore's Avatar
Photos: 0
http://www.unofficialbmw.com/e36/electrica...ice_lights.html
I did mine practically for free, I used a paperclip. I bent the ends into a U shape so it'd stick in the holes firmly. Short pins 7 and 19 with the paperclip for however many seconds you need. Pin 19 is ground, which is the same as the car body stated in the article. No need for a long wire, 50$ reset "tool" or any of that shit. Paperclip does the trick.
Rest of the procedure is as stated in that artcile, 3 seconds for oil lights, 9 seconds for service & oil lights.
I have a 1998, ODBII, worked without problems. (I even shorted the wrong pins at first few times, no fuses blown, no problems thus far :P )
Old 06-29-2004, 02:06 PM   #5 (permalink)
Defector
Photos: 0
I though you had had to have the tool for OBDII. Guess not. Good to know.
Old 06-29-2004, 05:09 PM   #6 (permalink)
97alpineM3's Avatar
Car: Blah
Photos: 0
97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light
I'm not much for shorting out anything that has to do with my ECU on my car... that just doesnt seem like a good working practice to me... thats just down right dumb in my opinion.....
You can buy a took made by Peake research.... it resets your service indicator... and your oil indicator.... and if your check engine light comes on... it will also tell you what codes your computer is sending out and tell you whats wrong with your car... its a pretty good tool... and it works for all e36's... but nothing past 2000... I think.... I would do it this way... it might cost 100 or so dollars... but as many times your gonna use it... its worth it... considering... the fact that if you accidently hit the wrong pin with the paper cut... there goes your computer..... and replacing one of those... is not cheap. its a lot more than 100 or so dollars... your choice though.. thats my opinion.
1997 E36 M3 1990 E30 325i
Old 06-30-2004, 02:46 PM   #7 (permalink)
Kissner's Avatar
Car: 1998/BMW/M3
Photos: 0
Thanks alot. I will just be sure to be extra careful wit the paperclip. Where can I buy a reset tool that u were talkin bout? 100 dollars sound like a lot to reset a light that doesn't matter but if i keep the car, like i intend to do, it would be a good idea. Thanks
Old 06-30-2004, 05:55 PM   #8 (permalink)
6th Gear Member
Kevin325i's Avatar
Photos: 0
All the reset tool does it ground that pin automatically when you tell it to recent the oil light or the service light. It's just like the BIOS on your computer, you move the jumper pin on it and it erases the information that it was storing.
Kevin
Kevin (President TBEA)
Old 06-30-2004, 06:21 PM   #9 (permalink)
Threadkiller
bitcore's Avatar
Photos: 0
thats *EXACTLY* what the tool does!!! Only thing is that it grounds it for 3 or 9 seconds specifically.
You must be thinking "short" as in short circuit, thinking that doing this is bad. Short circuiting a power source, That's bad, this is different. It's made to do this.
Well said kevin, Think of it as a paperclip jumper. It wont hurt the car unless you short the wrong pins, in which case you'll probably just blow a fuse.
Old 06-30-2004, 06:36 PM   #10 (permalink)
97alpineM3's Avatar
Car: Blah
Photos: 0
Understood... but you cant get the coded from your computer out of a paper clip... so HA....
Old 06-30-2004, 11:29 PM   #11 (permalink)
6th Gear Member
Kevin325i's Avatar
Photos: 0
Hey Alpine since you've got OBD II check out a "Drive Right Car Chip." It plugs into your OBDII port and reads off your speed and anytime you brake hard or accelerate hard. It's kinda nifty to have for racing. I only wish my car were OBD II. We use it in my dad's truck when he races it. Anytime I drive it I make sure I know if it's in there.... just in case. It can also read OBDII codes... but you've already got a tool for that.
Kevin
Old 07-01-2004, 12:09 AM   #12 (permalink)
Photos: 0
Fadec40 is an unknown quantity at this point
Yea, the paper clip will do the job. But the tool more than pays for itself when you want to retrieve codes when your "check engine" light illuminates.
Sure, you can use the paper clip to get rid of the light---pay now or pay later!
Fadec40 is offline   Reply With Quote
vB code is On
"help! I Want Better Headlights On My 3er!" jlevi 3-Series (E46, E90) 43 09-25-2008 08:34 PM
inspection light?? Trob 3-Series (E21, E30) 9 11-06-2005 07:29 PM
Inspection Light Question quiklilrex 3-Series (E21, E30) 7 03-01-2005 01:53 PM
Inspection service light? brosnan6 3-Series (E36) 5 03-15-2004 08:27 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
