Inside heat. - BMW Forum - BimmerWerkz.com
Old 01-31-2010, 08:50 AM   #1 (permalink)
Car: BMW 318i 8v 1995
jrharman is on a distinguished road
Inside heat.
I am wondering how long it normaly takes for the heating system to get hot in my car....
The front screen heat is hot as soon as it gets to the half way mark but if i change the setting to the face it is stone cold and the only way i can get anything is if i am pushing the car hard. Even if i put it to my feet its still hot its just this setting...
I have had it hot but it took over 30 mins.....
I have checked for ait bubbles and there is nothing also changed viscus fan see if that might have been problem (It needed changing anyway)
I am not losing any water as far as i can see also so not sure what it could be......
jrharman is offline   Reply With Quote
Old 01-31-2010, 09:09 AM   #2 (permalink)
Maybe there's an issue with the ducting and flaps that guide air to the upper vents through the heater core.
Old 01-31-2010, 09:35 AM   #3 (permalink)
Nick_318is's Avatar
Car: 1991 318is, 2005 Subaru Legacy GT
Nick_318is is on a distinguished road
Send a message via AIM to Nick_318is
Do you have a nob in the center vents with blue/red dots on it? If so turn it to the red dots and you will get heat on your face.
Originally Posted by yammahamma View Post
If I wanted to date you, I would have bought you dinner first.
Nick_318is is offline   Reply With Quote
Old 01-31-2010, 09:48 AM   #4 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
+1
Turkey Fleet Bond Holder
Old 01-31-2010, 09:57 AM   #5 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
+2, Ive heard of this so many times.....
Old 01-31-2010, 10:55 AM   #6 (permalink)
No disrespect but i keep my heat on red all the time ;-) basicly saying i'm not an idiot lol.... also where do the ducts come from witeshark?
Old 01-31-2010, 11:45 AM   #7 (permalink)
How does the controller that switches between defrost and bottom/upper vents seem to act? My thought is that only the defrost and bottom vents are directing air through the heater core.
Old 01-31-2010, 02:19 PM   #8 (permalink)
well as you know the E36 has 3 knobs..1st is air supply 2nd temp 3rd air distribution..
I always have my fan on 2 its always on hot and air is normaly on windscreen.. As i said if i put it directly on upper body its just cold and takes around 30-40 mins to even feel any warm air unless i am ramping the car..... all my vent are working fine i just get cold air from the upper body part.. the screen and feet are working normaly.
Also where is the heater core? i got 2 days off work so maybe i can try and clean it or something.
Old 01-31-2010, 03:00 PM   #9 (permalink)
You may be able to find the core on realoem.com
Old 01-31-2010, 10:38 PM   #10 (permalink)
92cleanbeam is on a distinguished road
I have the same problem. On my defrost and lower level vents my heater works fine. But when i switch to the face or mid vents it blows cold. It is the flapper. I have a 2 door so defrost is just enough heat for me. Good luck tearing it apart and let me know how it goes. The heater core should be a FUN job.
92cleanbeam is offline   Reply With Quote
Old 02-03-2010, 04:38 PM   #11 (permalink)
Lucky enough for me i have a bmw mechanic who is very cheap lol looks like its a job for him :-)
Old 02-03-2010, 04:51 PM   #12 (permalink)
well in that case let me know what he does to fix it so I can do the same. Please!
Old 02-03-2010, 04:51 PM   #13 (permalink)
Is the heater core the blower unit? If this is the case then its gonna be very expencive lol....
Old 02-03-2010, 05:39 PM   #14 (permalink)
The heater core is a mini radiator just like the engine cooling one. It's typically mounted inside the firewall in the dash assembly.
Old 02-03-2010, 05:41 PM   #15 (permalink)
I think either way you go, you will have to remove parts of the dash and YES it will be EXPENSIVE
heat inside cab Stunnd65 3-Series (E36) 4 06-29-2009 10:22 PM
Heat inside E39 Boot Grand 5-Series (E12,E28, E34, E39, E60) 3 07-30-2007 07:10 AM
No Heat wulley1 3-Series (E36) 16 03-09-2005 07:37 PM
No Heat!! gonzonick 3-Series (E36) 11 03-01-2005 09:35 PM
Dont Got Heat Inside E21 emmceethree 3-Series (E21, E30) 6 01-19-2005 11:33 PM
