Inlet hose on cylinder head ! - BMW Forum - BimmerWerkz.com
Old 04-25-2011, 04:15 AM   #1 (permalink)
facemask93 is on a distinguished road
Hi everyone , i'm quite new here , but i'll just say what a great forum this is
I've got a 92 318is automatic that has two problems , untill recently had a plug that would wet up with what smelled like radiator water , i'd clean the plug spray the lead with WD40 and the car would run fine for about a month , then the car would slowly start to misfire more and more , then i would repeat the process all would be fine again for a while , then the starter motor failed and in the process of fitting the new motor , the guy fitting it said the metal pipe that that the heater hose goes on to at the rear of the head had started to disintergrate , and when he reassembled the car it was leaking badly.
I have now stripped the inlet manifold off and can just about see the offending pipe and its rotting quite bad , has anyone been successfull getting this pipe out without stripping the car down any further , any idea's would be really helpfull , i'm hoping that if i can get this pipe out and a new one in , i can add some K seal to the water , the mechanic guy said i might have a porous head
Thanks
Rob
facemask93 is offline   Reply With Quote
Cylinder head jon_foisy 3-Series (E36) 7 11-11-2010 09:28 AM
Cylinder Head STEPHEN WILKERSON 3-Series (E36) 2 04-09-2010 01:41 AM
Blown head gasket, Cracked cylinder head... Blackoutmp M-Series (M1, M3, M5, M6) 8 04-04-2006 01:51 AM
head gasket vs cylinder head crack bderrick 3-Series (E21, E30) 3 07-04-2004 01:55 PM
Gas flowing cylinder head khassan 5-Series (E12,E28, E34, E39, E60) 1 06-17-2004 05:14 AM
