Im Screwed Help Me. - BMW Forum - BimmerWerkz.com
Old 07-26-2005, 09:56 PM   #1 (permalink)
zeidakiss's Avatar
zeidakiss is an unknown quantity at this point
hey alll,
i was trying to take out my intake hose today the one that goes across the radiator and i got that done, but the problem is that when i was looking for the throttle cable to rev it and see how it sounds but i actually had pull two different cables, then i just got lazy and went to the pedal inside and reved it. then i noticed that the abs and asc warning lights were on. after that i thought that if i turned it on and off the lights would go away but they didnt. then i took it for a drive and my breaks squeeked. can somone please help me with my problem?
thanx for your input.
zeidakiss is offline   Reply With Quote
Old 07-26-2005, 10:00 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
you must have done something else when you were mess'n around in the engine compartment to make the lights come on.... as for the break squeeking, that could be totally unrealated.
before most people speculate or diagnose though, what is the year and model you have?
Old 07-26-2005, 10:04 PM   #3 (permalink)
zeidakiss's Avatar
[snapback]365387[/snapback]
sorry for not posting the enough info
its a 97 318i and all i did was pull on the two cables, one is for the asc and the other is for abs... i think. thanx for the replys
Old 07-27-2005, 02:43 AM   #4 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile
Send a message via ICQ to jrhaile Send a message via AIM to jrhaile Send a message via MSN to jrhaile
ohh you just set off your alarms.. go get them reset. no biggie.
jrhaile is offline   Reply With Quote
Old 07-27-2005, 08:28 AM   #5 (permalink)
pcy
pcy is an unknown quantity at this point
Originally posted by zeidakiss@Jul 26 2005, 09:56 PM
hey alll,
[snapback]365386[/snapback]
You messed with the ASC throttle cable (not the main throttle cable). You will need to attach the ASC throttle cable properly snug fit and then loosen just a bit. Have someone else start the car while you watch the ASC throttle area; you will notice an actuator do a self test as soon as you start ignition. If there is anything obstructing that actuator, you will get those lights (ASC, ABS).
Since both lights are on, I am sure the problem is with the ASC.
ASC affects ABS; hence, you will get both lights.
pcy is offline   Reply With Quote
So, How Screwed Am I? What I Found In My Trunk! Delmarco 3-Series (E36) 27 08-28-2005 05:49 AM
I Screwed Up, Need Help JWK Wash & Detail 3 08-08-2005 05:19 PM
Axle screwed... Turbodefrost 3-Series (E36) 15 10-16-2004 10:12 AM
Getting screwed on Lease! callanish 3-Series (E46, E90) 4 07-09-2004 03:56 PM
