Illuminated Shift Knob - BMW Forum - BimmerWerkz.com
Old 02-15-2005, 01:45 PM   #1 (permalink)
loud068's Avatar
loud068 is an unknown quantity at this point
Exclamation
what is the easiest way to wire an illuminated shift knob on an e36
loud068 is offline   Reply With Quote
Old 02-15-2005, 02:15 PM   #2 (permalink)
sean's Avatar
sean is an unknown quantity at this point
Send a message via AIM to sean
what i did was run the positive side to the hazards light switch, then the negative to the screw that is directly under that switch. (you will see the screw after popping out the hazards light switch) the way i did it was to take out the switch, then it is in two parts, the side with the wires attached, and then the switch itself that snaps into the first piece. take these two parts apart, takes a little force a flat head screwdriver helps, then open the back of the piece attached to the wires. this just has 4 or 6 little clamps i forget exactly how many. once it is opened you can turn on the headlights of the car and find out which wires go on with the headlights, which are always running etc. easiest way to do this is to touch the positive wire to each wire in the switch piece (have the negative already attached of course) until the shift knob illuminates. since i wanted my shift knob to turn on when the dash lights turned on i took the wire and just simply stuck it in the hole that works when the lights are turned on. after this i held the wire in place as i re-attached the switch itself, and that held the wire in place. then just put it all back together and you have a working illuminated shift knob.
<img src='http://img.photobucket.com/albums/v146/318ibmw318i/the_sig.jpg' border='0' alt='user posted image' />
signature designed by crisby_E30
<span style='font-size:8pt;line-height:100%'><span style='color:blue'>
<span style='color:red'>Chairman</span> of the &quot;BMW-Forums...Cant hack it? Go Whack it... &quot; Mafia...&quot;We'll take your shoes&quot; </span></span>
sean is offline   Reply With Quote
Old 02-15-2005, 02:23 PM   #3 (permalink)
loud068's Avatar
thanx I'll give it a try
Old 03-04-2005, 09:50 AM   #4 (permalink)
93 325i's Avatar
I just did this last night in 10 minutes. Thanks! Awsome job on the write up
Complete mod list and pics:
My 1993 325i
Replacing M5 Shift Knob Wood Trim a_ok2me M-Series (M1, M3, M5, M6) 0 12-27-2004 06:57 PM
Loose Stick shield 3-Series (E21, E30) 6 09-02-2004 05:34 PM
97 540I Removing Automatic Shift Knob Phantomstorm Bimmer Talk/Motorsports Talk 1 04-18-2004 11:49 PM
Removing 97 540I Auto shift knob Phantomstorm 5-Series (E12,E28, E34, E39, E60) 4 03-23-2004 11:15 AM
