ignition problems? - BMW Forum - BimmerWerkz.com
Old 12-16-2009, 10:00 PM   #1 (permalink)
halleyjosh is on a distinguished road
ignition problems?
hello. I have a 95 318i I am new to bmw's, so I dont know much about them. I started it a few days ago and i noticed it was only running on three cylinders. so i checked for fuel pressure and it was good. i also made sure each injector was working. Next I checked for spark. every cylinder was firing except number one. I replaced the plugs and wires. nothing. I figured it was the coil pack, so I replaced it. the car is still doing the same thing. I checked the number one cylinder and it was not firing. It was not throwing a check engine light, but i decided to check the codes anyway. the code it was giving was ( 1....2....7....1 ) I have no idea where to go next. I know you guys know alot more about these cars than me so that is why I came here. thanks.
halleyjosh is offline   Reply With Quote
Old 12-18-2009, 05:06 PM   #2 (permalink)
anyone have any ideas?
Old 12-18-2009, 05:15 PM   #3 (permalink)
David Mc's Avatar
David Mc is on a distinguished road
1271 - ignition coil pack. An open-circuit or ground fault in the ignition wiring has occurred with an ignition coil. Place a timing light on the ignition wires and check for a signal. Also check the wires for faults, and check the spark plugs too. This will help in future Pelican Technical Article: Reading BMW Fuel Injection Fault Codes
David Mc is offline   Reply With Quote
Old 12-18-2009, 07:53 PM   #4 (permalink)
roma's Avatar
roma is on a distinguished road
dont forget to check to for compression
roma is offline   Reply With Quote
cant get my ignition OUT!!!!!!!!! hunter325i 3-Series (E36) 6 04-16-2007 10:04 PM
Ignition aheath 3-Series (E36) 24 02-14-2006 11:31 AM
Ignition aheath 3-Series (E21, E30) 1 02-04-2006 07:48 PM
Fuel/ignition Problems SHADOWLINE 3-Series (E21, E30) 1 05-01-2005 02:00 PM
E34 525i Ignition problems blackmanworking 5-Series (E12,E28, E34, E39, E60) 1 07-24-2004 03:32 PM
