HI guys & girls, i know there is other threads bout this, but none of those has helped my prob
Ive got a 96 plate 328i manual cabby, i call it "My Bank" cause thats where all my money goes! Anyway, when i start the car up, it idles fine, then when i drive it, every now and then when i pull up at a junction etc, it'll cut out, then fire up ok and off i go running fine! It does this whether its cold or hot!
Diagnostic check came up with mass meter, crankshaft sensor, cam shaft sensor and also Lamda sensor (which turned out to be split breather hose), ive renewed all these and ive changed all plugs, tried other coil packs, and even a new idle control valve!
Yet it still does it, had all codes cleared and rechecked last night, still showing crankshaft sensor, got another on order, maybe a dodgy new 1?
Im beginning to think fueling could be a possibility?
Has anyone had this and changed everything that i have???
