Idle Stall - BMW Forum - BimmerWerkz.com
Old 10-21-2004, 08:18 PM   #1 (permalink)
brien4787's Avatar
brien4787 is an unknown quantity at this point
Send a message via AIM to brien4787
I just got my car back from them looking at my pads, and when I went to start the car, it didn't start for a few trys. I finally got it working, but now, when at idle, I sometimes stall. I will see my RPMs go from 1000 and then it will start dropping sometimes when I am at rest. I have to hit the gas lightly to keep the RPM up so I do not stall when this happens. Does anyone know what's going on?
My friend said that it could be spark plugs, any thing else? Anyone have this problem?
brien4787 is offline   Reply With Quote
Old 10-21-2004, 08:45 PM   #2 (permalink)
Fadec40 is an unknown quantity at this point
Funny, I had the same problem a week ago.. Had to keep the accelerator depressed or else....stall.
Pulled up the codes, it pointed to the TPS, (throttle position sensor) Found the Throttle Body gummed up. Cleaned throttle body, problem solved.
This was my problem,,,yours could be the same, or one of many other things.
Fadec40 is offline   Reply With Quote
Old 10-21-2004, 08:51 PM   #3 (permalink)
Deloriant's Avatar
Deloriant is an unknown quantity at this point
Send a message via AIM to Deloriant
I had the same problem in my 300zx, it's probably your idle control. I'll call my mech. and see if he can fix it for ya.
<img src='http://i116.photobucket.com/albums/o17/M4yorThis/119575444991686.jpg'>
Deloriant is offline   Reply With Quote
Idle Problems BeelZibub 5-Series (E12,E28, E34, E39, E60) 10 07-10-2005 04:56 AM
Idle Problems, Intake Service Bulletin? rhansen162 5-Series (E12,E28, E34, E39, E60) 1 03-06-2005 07:18 PM
Warmed up idle puzzle. nightsurfride 3-Series (E21, E30) 2 02-03-2004 08:04 PM
