idle problem - BMW Forum - BimmerWerkz.com
Old 01-07-2006, 08:23 PM   #1 (permalink)
LYFE SUCK5
Ivan's Avatar
Car: 2008 Infiniti G35
Ivan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant future
Send a message via AIM to Ivan
idle problem
after coming to a stop and putting the car in neutral (any situation where the revs should drop back to idle basically) my car stays at about 1.7k rpm, then after a second drops to around 1, and then after another second or so goes back to idle, like 750 or so.
so what could this be? idle speed control motor? how important is it that i get it fixed? i dont make a whole lot of money at the moment.
Ivan is offline   Reply With Quote
Old 01-07-2006, 09:24 PM   #2 (permalink)
Get some carb cleaner and do it yourself...
Go to Walmart and get a spray can of Berryman's Chemtool spray carb cleaner and do it yourself for less than $5.
Here's a link to the Pelican article on cleaning the ICV on the 4 banger. The 6 is a little more hidden. Clean out the throttle body while you're in there.
http://www.bmwe36tips.20m.com/unstable-idle.htm
Mike
Hamfisted is offline   Reply With Quote
Old 01-07-2006, 10:13 PM   #3 (permalink)
LYFE SUCK5
Ivan's Avatar
i have a k and n cone filter in there, i have heard they are worse than stock filters and dont filter the air as well. could this be why the icv valve might need cleaning?
stupid k&n:
Old 01-07-2006, 11:19 PM   #4 (permalink)
kyle_baker's Avatar
kyle_baker is an unknown quantity at this point
Send a message via AIM to kyle_baker Send a message via MSN to kyle_baker Send a message via Yahoo to kyle_baker Send a message via Skype™ to kyle_baker
stupid k&n:
not necessarily, over time the icv can become dirty with any type of intake. it is normal that you clean it atleast once by now. this is a common problem, but not a very serious one. easy fix, just takes a little bit to complete.
kyle_baker is offline   Reply With Quote
Old 01-07-2006, 11:28 PM   #5 (permalink)
LYFE SUCK5
Ivan's Avatar
thanks ill check it out
Old 01-17-2006, 12:34 PM   #6 (permalink)
agtur2001's Avatar
Car: 1994 325ic
agtur2001 is an unknown quantity at this point
Cool
I had the same issue... used WD40 on the cable links controlling the IDLE and Throttle...
Problem comes back after a few months... then I put more lube.
agtur2001 is offline   Reply With Quote
Old 01-17-2006, 05:42 PM   #7 (permalink)
vwk
vwk is an unknown quantity at this point
Maybe a strange tip... but DOES work...
Just be very, very carefull...
Take out your filter, have a buddy start your car... before you let the car start, spray in some pure ether... That will almost clean anything that's causing your car to run bad on idle.. considering it's in your intake, not the lambdasonde etc.
Euro E36 M3 3.2 Rebuild Project
27 years
vwk is offline   Reply With Quote
Old 03-13-2006, 10:08 AM   #8 (permalink)
Redbullrr's Avatar
Redbullrr is on a distinguished road
I'm having a similar problem. The plastic screw for the throttle cable broke in half. So the car jerks in first gear and revs when I'm still. I broke it this weekend by accident, possibly due to old age. I mean this part is freaking plastic, I don't get why they would use plastic, when a freaking bicycle has them in medal for brakes. Anyhow, going to put some epoxy to get it back together, adn lube up the throttle with some Tri-Flow. See how it goes.
Redbullrr is offline   Reply With Quote
Old 03-13-2006, 10:33 AM   #9 (permalink)
kyle_baker's Avatar
haha, thats a good point, hope you get it fixed. epoxy should hold it well.
325i white smoke and idle problem puppie 3-Series (E36) 3 10-22-2005 07:57 AM
Help!! Urgent Idle Problem BMW328 3-Series (E36) 6 06-27-2005 12:07 PM
E39 Cold Idle Problem, Solution TWKTCC 5-Series (E12,E28, E34, E39, E60) 6 04-05-2005 03:37 PM
Idle Problem 93 325i 3-Series (E36) 21 12-07-2004 09:42 AM
