iat sensor - BMW Forum - BimmerWerkz.com
Old 06-26-2008, 03:28 PM   #1 (permalink)
Car: 1997 328i touring
dudehog is on a distinguished road
Angry iat sensor
ok this is really annoying me. where the hell is this damn thing? i've been told it's in the air box.............nope. if anyone knows where to find this blasted thing . please let me know. i know it's got a 2 pin plug that goes on it and thats about it. typical ain't it. ta folks.!!!! the dude.
dudehog is offline   Reply With Quote
Old 06-26-2008, 03:31 PM   #2 (permalink)
saylee's Avatar
Car: 94 325 / 93 MR2 turbo...
saylee is on a distinguished road
Send a message via AIM to saylee
are you talking about the auxiliary thermostat sensor....???
BMW Auxiliary Water Thermostat
" The path of righteous is like the first gleam of dawn, shining ever brighter till the full light of day."
Proverbs 4:18
saylee is offline   Reply With Quote
Old 06-26-2008, 03:34 PM   #3 (permalink)
na the intake air temperature sensor. not sure whether you guys have a different name for it.
Old 06-26-2008, 03:40 PM   #4 (permalink)
saylee's Avatar
i think the only plug that plugs on the back of the intake box is the Auxiliary Thermostat Sensor...
Proverbs 4:18
Old 06-26-2008, 03:41 PM   #5 (permalink)
saylee's Avatar
check out that link that i posted at the top...it has a picture of it...and it is a temperature control device..
Proverbs 4:18
Old 06-26-2008, 03:46 PM   #6 (permalink)
thanks man i'll check that out tomorrow, it's time for to go to bed (work in the morning) .....................rock n roll!!!!!!
Old 06-28-2008, 09:28 AM   #7 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Talking
Intake Air Temp(IAT) sensor is located on the intake manifold. You'll find the connector on the underside.
Old 07-25-2008, 06:25 PM   #8 (permalink)
holyoption is on a distinguished road
Did you solve the issue? i'm also having same problem, you probably bought the one of the performance wanna be chip from ebay just like me
i driver 02 bmw 325i sedan, instruction is horrible!
holyoption is offline   Reply With Quote
Old 07-26-2008, 02:49 AM   #9 (permalink)
more than likely . the advert for it has a glossy black lowered 5 series i think.i gave up in end. the bmw dealer looked at me as if i was talking in some strange foreign language when i asked him to locate it for me. think i'll just drive it as it is. thanks for replying.
Old 07-26-2008, 09:08 AM   #10 (permalink)
Talking
for your year & model, the IAT is located on the underside of the intake manifold, right by the throttle body.
Old 02-24-2011, 12:57 AM   #11 (permalink)
EdMic is on a distinguished road
Since it is upside down it is hard to pull out. Something is catching it on the dge. How do you remove it? Is it supposed to be loose? I'd like to put some sealant to make it tight and seal it from vacuum leak.
EdMic is offline   Reply With Quote
Old 02-24-2011, 01:07 AM   #12 (permalink)
It's under the intake manifold somewher nea the center near the throttle body. You'll have to remove the throttle body since it is in the way. Once removed you can see it thru the intake manifod round hole. It is upside down. Unplug it by pushing in the spring wire lock while pulling the plug down with the other hand. I'm trying to remove it right now but couldn't pull it out. Even if I twist while pull ing it down it won't come out. Something is catching it on the edge. I don't want to force and break it. I just want to remove it and put some sealant to keep it tight and prevent vacuum leak. Need some help here. Thank you.
Iat Sensor flemishlion 3-Series (E46, E90) 6 06-13-2005 11:59 AM
Iat Sensor smx 3-Series (E36) 4 03-11-2005 07:34 AM
Iat Sensor n1knightmare 3-Series (E36) 0 03-06-2005 07:22 PM
Iat Sensor Plug foe69 3-Series (E46, E90) 0 10-12-2004 09:15 AM
IAT SENSOR! M5power 5-Series (E12,E28, E34, E39, E60) 4 03-28-2004 11:01 PM
