I replaced valves now car don't wanna start need help e36 M40 motor 318i - BMW Forum - BimmerWerkz.com
post #1 of 6 (permalink) Old 01-05-2013, 02:59 PM Thread Starter
phillip1 is on a distinguished road
I had 4 valves that bended because of belt that broke I took the head off
and got the valves replaces I reffited the head and did the timing setup according to specs but now the car don't wanna start< Any Idea what can cause it it's a 1994 318i e36 with the M40 motor timing belt not chain ??????
phillip1 is offline
post #2 of 6 (permalink) Old 01-05-2013, 09:43 PM
Ivan413's Avatar
Ivan413 is on a distinguished road
Does it sound like it wants to turn over or it's completely dead ?
Sent from my iPhone using AutoGuide.com Free App
Just your avg 17 year old with an e36 318i as a DD!
Ivan413 is offline
post #3 of 6 (permalink) Old 01-06-2013, 02:37 AM Thread Starter
The motor turns it sounds like if it wants to start but the moment you stop turning the key it dies again, I have another question when you do the timing set up between the camshaft and novalis must piston 1 and 4 be all the way up.
Because as per pictures how to set up the timing that i got from bimmerworks
how to do the timing if i do it according to the way they show piston 1 and 4 stops 3mm from the top is that correct???
phillip1 is offline
post #4 of 6 (permalink) Old 01-06-2013, 10:44 AM
Ivan413's Avatar
Yes there's an arrow on the crank and when it points straight up is when the motor should be in TDC (Top Dead Center) where cyl 1 & 4 should be the highest but your belt could possibly off a tooth or so if you didn't measure it accurately with the arrow and did it by the naked eye. I'm assuming when you did the valve replacement you had the head machined and checked for cracks and bought new gaskets and head studs, so you might wanna look into doing a compression test to see if those gaskets are big enough because the head tends to warp a bit under heat from the machine as well as the amount of surface that was cut off.
Ivan413 is offline
post #5 of 6 (permalink) Old 01-07-2013, 01:39 PM Thread Starter
Hi Ivan
Many Thanks for your help I came right my cam pulley was abit warn out so every time
I set the timing in the moment I put the belt on it throws the novalis out so I had to replace the pulley to get the exact alignment.
many thanks
Phillip
phillip1 is offline
post #6 of 6 (permalink) Old 01-07-2013, 01:44 PM
Ivan413's Avatar
Glad she's back up and running.
Ivan413 is offline
320i won't start when the motor is at operating temperature 320iDriver 3-Series (E46, E90) 1 08-11-2012 06:40 PM
i wanna try something with my motor AE86PandaDuda 3-Series (E21, E30) 4 08-10-2009 11:35 PM
E30 318i Motor swap to E21 320i o skool 320i New Members Check In 0 09-09-2008 06:49 PM
Replaced battery and now car won't start moro 3-Series (E36) 1 04-12-2008 02:00 PM
Motor Cranks But Wont Start AllEyezOnMe 3-Series (E36) 4 11-22-2004 12:16 PM
