i need pro bmw help - BMW Forum - BimmerWerkz.com
Old 07-20-2004, 06:47 PM   #1 (permalink)
AutoFan is an unknown quantity at this point
Well now when i rev up my car and im under the hood i can hear a grinding noise
right by the vanos unit.. you dont hear it at idle but when you rev it up it sounds like
a gear isnt grabing. can the vanos unit break , i know i cant fix it. i think im screwed ghead
AutoFan is offline   Reply With Quote
Old 07-20-2004, 06:51 PM   #2 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile
Send a message via ICQ to jrhaile Send a message via AIM to jrhaile Send a message via MSN to jrhaile
what rpms is is inbetween? mine scratches/grinds a bit between 1000-2000rpms... I'm having my car looked at soon for it..
jrhaile is offline   Reply With Quote
Old 07-20-2004, 07:21 PM   #3 (permalink)
yeah the higher you rev it the more it grinds. i can only imagine what this will cost to fix. also does anyone else hear like a tick noise underneath the car when at idle?
Old 07-20-2004, 07:54 PM   #4 (permalink)
Kevin325i's Avatar
Yeah the tick is normal, it's just noise from the valvetrain, can't help you with the vanos though. It almost sounds like the teeth on the gear for the vanos got stripped...
Kevin (President TBEA)
Old 07-20-2004, 08:15 PM   #5 (permalink)
should i not be driving my car then? it seems to run fine. also is the vanos expensive?
Old 07-20-2004, 08:36 PM   #6 (permalink)
robbins6103's Avatar
robbins6103 is an unknown quantity at this point
Send a message via AIM to robbins6103
If your really concerned, I would seek professional help from a dealer or authorized BMW mechanic.
<img src='http://memimage.cardomain.net/member_images/8/web/740000-740999/740645_1_full.jpg' border='0' alt='user posted image' />
robbins6103 is offline   Reply With Quote
Old 07-20-2004, 08:59 PM   #7 (permalink)
whosurdaddy is an unknown quantity at this point
how old is the car?
whosurdaddy is offline   Reply With Quote
Old 07-20-2004, 09:20 PM   #8 (permalink)
its a 94 with 118k mi on it
Old 07-20-2004, 10:54 PM   #9 (permalink)
Threadkiller
bitcore's Avatar
Yes, as robbins6103 said, I would probably go to a dealership or authurized BMW mechanic for this one as well if you can't find the exact problem.
Are you sure it's not your AC compressor clutch slipping? my A/C clutch squeels like no tomorrow. Turn the AC off and see if it's the same.
Old 07-21-2004, 04:08 AM   #10 (permalink)
rmxpete is an unknown quantity at this point
hey I also agree with the above information, but more so the last by bitcore as my airconditioning was squling like a little bitch when the magnetic switch failed in it! only cost me about 100 bucks to fix it, and if I turned it off it stopped the noise so I would recommend taking it to a proper mechanic, but if you got a couple of days before you go; try eliminating as many differant things as you can, its possible that it could be a bearing on the belt which is on the way out, the really easy way of eliminating that problem is to get someone to start the car whle you hold a screwdriver "a long long one" on the center of each bearing then put your ear on the end of the screwdiver, it will act as a "stepascope" "spelling" and you will very quckly find out wheather or not the bearing is on the way out! A bmw technicain showd me this and it does work!, however in saying that if your not mechanicly minded, just take it to some one that is!!! I would hate to see someone loose there fingeres in that fan
hope you solve this prob and kep us posted on what it is!!
rmxpete is offline   Reply With Quote
Old 07-21-2004, 06:24 AM   #11 (permalink)
Mr White G's Avatar
Mr White G is an unknown quantity at this point
Get the garage to check that every thing is nice and tight. I know they develop problems between 60 and 70k miles so it might be time for some new belts.
<span style='color:blue'>&quot;So my BM makes me a flash bastard? Then I guess you're just keeping it real from the seat of your nova?&quot;</span>
<span style='color:gray'>&quot;...and the home of the brave..... is bravey 130bhp from a 7 litre engine? 100bhp/litre or don't bother building it!&quot;</span>
<span style='color:red'>&quot;Aaahh the UK; where every road is jammed, under construction, poorly maintained and unfairly policed, at least we don't get over-taxed for it........ HA HA HA!&quot;</span>
Mr White G is offline   Reply With Quote
Old 07-21-2004, 08:19 AM   #12 (permalink)
Threadkiller
bitcore's Avatar
Preformance lightweight pully upgrade as welll? :lol:
