i need help please!! - BMW Forum - BimmerWerkz.com
Old 04-29-2003, 01:08 AM   #1 (permalink)
hodges is an unknown quantity at this point
Send a message via Yahoo to hodges
will someone help me please. im having serious electrical probs
Matt 93' 325i sedan
92,000k miles
tinted windows: done (130.00)
clear side markers: done (30.00)
remove baffle: done (free)
next 2 upgrades
performance chip
white or aluminum gauge faces
hodges is offline   Reply With Quote
Old 04-29-2003, 01:18 AM   #2 (permalink)
matt
Guest
Posts: n/a
All of my gauges quit working and so did my cruise. I checked all the fuses and their fine, what next?
Old 04-29-2003, 02:20 AM   #3 (permalink)
FruityOne's Avatar
FruityOne is an unknown quantity at this point
Send a message via AIM to FruityOne
just because when a fuse doesnt look busted it could still be busted...its happened to me before. or your instrument cluster is dead and so is your cruise
93 325is - SOLD (white car in sig)
92 325i - 220rwhp/205rwtq (RIP)
02 GSXR 600 - 107rwhp/48rwtq
95 M3 - 220rwhp/205rwtq
President & Founder OF S50 Swap Club
THC the three most powerful letters in my veins...
FruityOne is offline   Reply With Quote
Old 04-29-2003, 02:24 AM   #4 (permalink)
I used a tester on the fuses and I just think its real strange that it all went out at the same time. It could be the sender unit or voltage regulator.
Matt 93' 325i sedan
92,000k miles
next 2 upgrades
performance chip
Old 04-29-2003, 08:08 AM   #5 (permalink)
Ski
Sheer Driving Pleasure
Ski's Avatar
Ski is an unknown quantity at this point
Also check for loose or poor ground connections..what is your ride hodges??
My Jet Black's
'03 3.0i Z4 Loaded
'02 325Ci Loaded
'06 330xi Loaded
Ski is offline   Reply With Quote
Old 04-29-2003, 03:38 PM   #6 (permalink)
I own a 93 325i sedan and I love it. I'm guessing the pic is of your ride.
Matt 93' 325i sedan
92,000k miles
next 2 upgrades
performance chip
Old 04-29-2003, 05:20 PM   #7 (permalink)
DesmoBob's Avatar
http://www.bimmerforums.com/forum/showthre...1342#post771342
Old 05-02-2003, 11:00 PM   #8 (permalink)
Please Im fixing to have buy an instrument cluster and they r not cheap. If any on knows any possible solutions let me know.
Matt 93' 325i sedan
92,000k miles
next 2 upgrades
performance chip
Old 05-02-2003, 11:51 PM   #9 (permalink)
GreenDragon's Avatar
GreenDragon is an unknown quantity at this point
I'm going to have to assume you did not follow Desmo's link, so I took the liberty of copying it and psting it here for you. If this is what your problem sounds like, or even just to be sure, I would suggest you at least take a look.
"Hey guys. Just letting you guys know to be carefull because I just caught something really bad in my 325is. I was driving one day and then all of a sudden things started to go really wrong. I lost my headlights, I had no interior lights, no dash lights, and no turn signals. MY OBC was going crazy saying all these electircal failures were going on. It was night and all that worked were my foglights to light up the road. I stopped by the dealership I work at and opened up the fuse box and saw about 10 fuses blown. I replaced them all and then they instantly blew out. Then we noticed something interesting, all my lights didn't work, except my tailights. They were still lit up. The mechanics traced all these problems to the wiring harness that goes from the car to the trunk. If you look on the left side, when your trunk lid is up, you see a thing of wires wrapped up in a black covering. We took off the covering and you won't beleive what we found.
ALL THE WIRES OVER TIME RUBBED AGAINST EACHOTHER AND THE WIRE COATING RUBBED OFF EVENTUALLY AND ALL THE WIRES WERE TOUCHING EACHOTHER. FROM YEARS OF OPENNING AND CLOSING THE TRUNK, THE WIRES GET WEAK AND SO DOES THE WIRE COATING. Mine was really bad, it went all the way into the car, luckily it stopped before it went deep into the car where I would most definetely not be able to reach it.
I RECOMMEND EVERYBODY CHECKING THIS OUT ASAP. SAVE YOURSELF ALOT OF MONEY AND PREPARE AHEAD. I INDIVIDUALLY WRAPPED EACH WIRE IN ELECTIRCAL TAPE.
IF THIS HAS HAPPENED TO YOU, POST. I can't be the only one.
UPDATE : YOU HAVE TO TAKE OFF THE BLACK PLASTIC COVERING AND THE RUBBER LIKE TUBE TO EXPOSE ALL THE WIRES BEHIND TO BE SURE IF THE WIRES ARE FRAYING. YOU WON'T BE ABLE TO TELL ANYTHING WITHOUT CUTTING THROUGH AND SEEING.
It makes sense that when you open and close your trunk that those wires are going to rub against eachother everytime you open and close."
<span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
GreenDragon is offline   Reply With Quote
Old 05-03-2003, 01:31 AM   #10 (permalink)
Yes I did read it and my problem is more neutralized in one area. I did not blow any fuses and all my lights work properly. My gauges and cruise do not work. I will assume that the cruise will not work if the speedo doesnt. I probably will end up replacing the entire cluster and Im gonna like it. I have one more card to play with this BITCH (325i). I am going to try and replace 4 transistors on the back of the cluster that are known for being the cause of most bad clusters. If that works then I will consider this a victory and go spend the $$ on drugs and booze!!
Matt 93' 325i sedan
92,000k miles
next 2 upgrades
performance chip
Rate My Mods Please!! ooibhuskyoo 3-Series (E36) 24 11-23-2004 04:43 PM
I NEED SOME HELP PLEASE!! venomviper69 3-Series (E36) 2 01-02-2004 07:35 AM
Opinions Please!! Balucanb 5-Series (E12,E28, E34, E39, E60) 13 08-06-2003 01:50 AM
