I need a DME (0 261 203 282) for my 94' 318is - BMW Forum - BimmerWerkz.com
Old 11-08-2010, 06:38 PM   #1 (permalink)
jameskeith is on a distinguished road
I need a DME for my 1994 318 is
part # 0 261 203 282 silver sticker.
jameskeith is offline   Reply With Quote
Old 11-09-2010, 05:21 AM   #2 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
Try Strictly German 888 992 7434
Good luck
Riding in style
Old 11-09-2010, 04:49 PM   #3 (permalink)
Thanks, Preciate the input!
Old 11-09-2010, 07:48 PM   #4 (permalink)
charliebrown408 is on a distinguished road
You can follow this website and you can take help from this link.
Here can purchase auto parts and accessories for all the car products.
Discount Auto Parts Store | Auto Parts Coupons code | Auto Discount
auto discount
charliebrown408 is offline   Reply With Quote
Old 11-09-2010, 08:12 PM   #5 (permalink)
Thanks for the link. I'm trying to find the right part number. I wonder; when I get one, probably used with a warranty, if I should just take the factory chip out of my original one and put it in the one I get so i don't have to worry about the key code. any thoughts. Or do I even need to worry about that if I get one with the same part number. The chips are easy to swap.
Old 11-10-2010, 07:02 AM   #6 (permalink)
brettski's Avatar
Give them a call, they should know what you will need to do.
Riding in style
Old 11-10-2010, 04:46 PM   #7 (permalink)
Hey, thanks for all the input, I did find out that as long as all of the numbers are right I don't have to worry about anything else. Just Plug and Go!
Old 11-10-2010, 08:17 PM   #8 (permalink)
Mackay's Avatar
Car: Black e36 325is
Mackay is on a distinguished road
Welcome, BMW fans! is amazing for finding parts/part numbers. They have really nice diagrams too. Pelican Parts - Porsche Parts & BMW Parts - Automotive Parts and Accessories - Porsche & BMW is my favorite parts sites
Mackay is offline   Reply With Quote
Old 11-10-2010, 10:39 PM   #9 (permalink)
Thumbs up
Thanks, I'll check those sites out!
Well, found out that the best and least expensive fix for the "Water Logged" DME problem that gives so many 3 series owners such grief is this....
remove the plastic wind sheild cow then the black plastic rectangular box that houses part of the wiring harness attached to the firewall just below it. Vaccum out all of the leaves and squirl nut stuff (How do they get in there anyway?)that builds up over the years clogging the only drain port there is for all of the water run off from the rain and high powered car washes. The problem is the design in the rubber outlet tube for the drain (Located in the lower corner on the passenger side just inside of the compartment for the air blower housing)
The tube actually has a "Pinched" end by design where the water evacuates the tube. Leaves, dirt, and squirl poop literally plug up the tube causing the water to build up and finally drain right into the adjacent DME compartment killing the car's computer leading in most cases to the infamous "My Car Won't Start Syndrome" (MCWSS) I simply remove the tube and cut it completely off about 1/2" below the 90 degree angle and reinstalled it. Once i did this I dumped a gallon of water right into the compartment and it drained as quick as the water poured in. They make a new updated drain kit for these cars, but cost you money. The way I did mine is safe, gives you just as good if not better results, and best of all it is free.... except for the time you put into doing it.
WANTED:94'-95' M5 "throwing star" wheels nellmike Wheels and Tires 0 01-05-2007 06:45 PM
92 E36 318i Ecu 0 261 200 990 muk5 OEM Parts 0 10-12-2006 10:28 PM
94' 325is sports mode? 325is. 3-Series (E36) 25 10-21-2005 06:43 PM
Lexion Type 203 + Michelin Ps2 Rooz Wheels and Tires 0 08-18-2005 03:04 PM
Dme mizzy 3-Series (E36) 5 01-18-2005 10:05 PM
