Hub Issue, Or is it... - BMW Forum - BimmerWerkz.com
Old 04-09-2009, 08:56 PM   #1 (permalink)
tsiklauss is on a distinguished road
So earlier this week I am driving to work and my wheel begins to have a slight shimmy in it. I think it is a low tire get to work and they look fine. Over the last few days it has gotten worse and on the way today it is reasonably worse. When I pull into my spot and get out my right front wheel is putting off a large amount of heat. I work at a junk yard and had a set of hubs off on the shelf so I have my mechanic come pick up my car and the hubs to put them on for me. He calls me from his shop and tells me that my hub seems fine other then being a little dry, but my left shock is blown. Any ideas on what this would be? I wont have a chance to start tearing it apart until this weekend so any clue would be great.
tsiklauss is offline   Reply With Quote
Old 04-10-2009, 12:17 AM   #2 (permalink)
Mr. Clean
BimmerE39's Avatar
Unfortunately, I wouldn't really know where to start as I can't see your car. if the shock is indeed blown it is possible that the extra weight on that side of the car due to lack of support could have caused the additional heat. Let us know what you see when you get a chance
Old 04-24-2009, 01:13 AM   #3 (permalink)
tractiondeprived is on a distinguished road
99% of the time this issue is caused by the lower torsion arm bushing being torn. take the wheel off and look at the lower control arm (L shaped piece that attaches to the bottom of the hub and goes back and attaches to the subframe then goes back to the frame). look at the bushing where it attaches to the frame, i betcha its torn. luckily they're only about $30 or so new. lot cheaper than a $130 wheel bearing.
tractiondeprived is offline   Reply With Quote
Roof issue red light flashing! (and Sat Nav issue too!) doopranal Z3 / Z4 /ZM 0 03-24-2009 06:25 AM
Hub and bearing repair Dathaeus 3-Series (E36) 3 12-08-2008 09:08 PM
HELP HUB ASSEMBLY FOR THE REAR? question Buckt 3-Series (E21, E30) 2 06-04-2008 11:23 AM
Crank Hub 85-325e 3-Series (E21, E30) 2 03-20-2005 09:12 AM
E30 Rear Brake Hub vinnie 3-Series (E21, E30) 2 02-11-2005 07:30 PM
