» Sponsors
» Sponsors
Old 06-24-2004, 01:56 PM   #1 (permalink)
Photos: 0
justin93 is an unknown quantity at this point
Does anyone know how to hardwire a radar detector?
Thanks
1993 318I
justin93 is offline   Reply With Quote
Old 06-24-2004, 04:43 PM   #2 (permalink)
Defector
El Presidente's Avatar
Photos: 0
You need to find a switched 12V wire and use that to power the unit. If the unit has memory settings that go away when it loses power, you need to wire it to a constant 12V source.
Where do you want to mount it? I can better guide to a good wire but I need to know where it's going.
Old 06-24-2004, 05:02 PM   #3 (permalink)
Photos: 0
I want to mount it up by the rear view mirror....so hardwire it to the sunroof switch or something
1993 318I
Old 06-24-2004, 05:12 PM   #4 (permalink)
Defector
Photos: 0
1. Pop out the sun roof switch using your fingernails or a screw driver.
2. Put your finger in the hole and pull down on the panel. the whole thing will come down, but you have to pull hard.
3. Disconect the sun roof switch.
4. Pop out the three lights (dome light and two map lights)
5. There will be 5 wires comming out of it. you want the green one for power.
6. Connect your detector wires as you see fit (solder, crimp, wire nut, etc). Make sure it works, then stick the wires back in place.
7. Run the Radar wire out between the dome lights and the sun roof switch pannel in the corner.
8. Put in the lights and panel back on and plug in the sun roof switch.
9. Mount in front of the mirror.
Old 06-24-2004, 06:43 PM   #5 (permalink)
Car: 2008 128i
Photos: 0
there is a link to an illistrated guide someplace around here.
2008 128i Jetblack
Old 06-24-2004, 08:13 PM   #6 (permalink)
Photos: 0
Thanks guys
1993 318I
Old 06-24-2004, 08:52 PM   #7 (permalink)
Threadkiller
bitcore's Avatar
Photos: 0
Make sure the radar detector likes 12\14 volt sources if you hardwire it without a DC/DC converter, or you might %*#% it up. ... or do the radar detectors now a days all run on 12v? (I have this busted one my mom gave me that runs on 9v for some dumb reason)
vB code is On
Radar Detectors paulg 5-Series (E12,E28, E34, E39, E60) 21 06-29-2005 05:35 PM
Radar Detector Always Powered On docsid Audio and Electronics 32 07-28-2004 01:48 AM
Radar Detectors zdevcic 3-Series (E46, E90) 3 01-26-2004 07:46 PM
