How To Gain Some Horses - BMW Forum - BimmerWerkz.com
Old 04-14-2005, 11:53 AM   #1 (permalink)
vmelikRUS is an unknown quantity at this point
I have a 97 328i w/ manual trans. All you people here seem to have top of the line cars. You can get top performance out of your cars. I love my Beemer, but I don't want to spend a fortune upgrading it. I only spend money on needed repairs, and wouldn't change thinks like the muffler for a little boost. However, I do wish I could do something not too expensive that will give me more power. Is there a particular component that will give me wings? I know the computer chip controls alot of things, and is the cause of so many limitations. What is the one thing I could do to boost up my 328 without spending alot money on little extras. I remember I had a 96 Nissan Maxima w/ manual trans. I used to have a lot of power, I could rape anyone, but the 328 seems a little weak.
vmelikRUS is offline   Reply With Quote
Old 04-14-2005, 11:55 AM   #2 (permalink)
mrkbik's Avatar
mrkbik is an unknown quantity at this point
The 328 should be a fair amount faster than a '96 maxima. If it seems weaker than that car, there is something wrong. Anyway, you are correct about the chip. I'd get a conforti chip if I were youy and only wanted one thing. You can get one from www.turnermotorsport.com.
Edit: You can't get the chip for OBDII, you would have to get the shark injector.
<img src='http://www.bcarmory.com/Moonclips/6-shot-FMC.jpg' border='0' alt='user posted image' />
I love scotch. Scotch scotch scotch.
mrkbik is offline   Reply With Quote
Old 04-14-2005, 12:13 PM   #3 (permalink)
[snapback]332292[/snapback]
So I could get about 20 extra horses for $250, not bad. So this would be the biggest single addition right? I couldn't find anything there for my e36 which is 97. They have intakes and shark injectors that suit my type. Do they give relatively more horse power, since they seem to cost more then the chips?
Old 04-14-2005, 12:17 PM   #4 (permalink)
tomctx's Avatar
Originally posted by vmelikRUS+Apr 14 2005, 01:13 PM--><div class='quotetop'>QUOTE(vmelikRUS @ Apr 14 2005, 01:13 PM)</div><div class='quotemain'><!--QuoteBegin-mrkbik@Apr 14 2005, 10:55 AM
The 328 should be a fair amount faster than a '96 maxima.* If it seems weaker than that car, there is something wrong.* Anyway, you are correct about the chip.* I'd get a conforti chip if I were youy and only wanted one thing.* You can get one from www.turnermotorsport.com.
Edit:* You can't get the chip for OBDII, you would have to get the shark injector.
[snapback]332306[/snapback]
[/b][/quote]
No,unfortunately they don't. OBD II doesn't respond as well as OBD I to modification.
Old 04-14-2005, 02:43 PM   #5 (permalink)
B_w.'s Avatar
Car: turbo e36
B_w. is an unknown quantity at this point
m50 intake manifold with a conforti shark injector will give great gains at higher rpms. a crank pulley should give some good hp and torque gains. fan delete kit frees up a few ponies. underdrive pulleys. limited slip differential. m3 cams give great gains but cost a little more.
or upgrading your suspension will make driving a lot more fun
turbo 2.8
cp pistons, eagle rods, gt35r, tec3
B_w. is offline   Reply With Quote
Old 04-14-2005, 08:37 PM   #6 (permalink)
jshearer's Avatar
Car: 1994 325is
jshearer is an unknown quantity at this point
Originally posted by vmelikRUS+Apr 14 2005, 12:13 PM--><div class='quotetop'>QUOTE(vmelikRUS @ Apr 14 2005, 12:13 PM)</div><div class='quotemain'><!--QuoteBegin-mrkbik@Apr 14 2005, 10:55 AM
[/b][/quote]
Your car is OBDII so you have to shark it, you can't put in a chip. The shark is the same basic thing just the way you change the software is different(reprogram versus a new chip with different program on it). It will still give you some good gains but not as much as a chip will for the 325. From what I hear the M50 manifold and shark is a great addition like B_w. said.
<a href="http://imageshack.us"><img src="http://img217.imageshack.us/img217/3466/quicksignature20te.jpg" border="0" width="600" alt="Image Hosted by ImageShack.us" /></a>
jshearer is offline   Reply With Quote
Old 04-14-2005, 09:15 PM   #7 (permalink)
NeverLeaned is an unknown quantity at this point
Send a message via AIM to NeverLeaned
I'd say you should take a serious look at your car if you feel like its under-performing. I just got through a bad tank of gas and i could feel the difference on the pedal
Mods + BMW = expensive
There are a few mods on the cheapo side that you might find helpful
m50 Manifold--> probably the best $ per pony for our cars. If your handy under the hood you can do it for <$150.
DIY (or cosmos) cold air intake
Fan delete mod
Im probably missing something there, but everything else will cost >$150(alot more hehehe) a pop from there on out.
If your looking for a taste then give the DIY intake baffle removal a try... at least its free
A search on any of those topics should provide a wealth of information.
1996- BMW 328IS
<img src='http://img.photobucket.com/albums/v242/gws226/TEX/neverleanedsig.jpg' border='0' alt='user posted image' />
Performance: Zimmerman Cross Drilled Rotors-- PBR Deluxes-- Cosmos CAI---- Turner Pulley Kit--- Fan Delete mod---
Beauty: 18 polished M-Parallel replicas, Inpro Euros w/ Enchanced Angel eye kit, 20% tint
Clear corners/sidemarkers ---- Eurospec (Depos)
To do list:
Suspension--- researching
UUC System U TDM- 3/05
M50 manifold converstion 3/05
NeverLeaned is offline   Reply With Quote
Old 04-15-2005, 01:32 AM   #8 (permalink)
Power Shifting
Cruzin 323is's Avatar
not to get off of topic, but your wrong about the maxima.. a 96 maxima.. had 190 hp's just like your bimmer.. it also weighed 3400lbs.. so your bimmer should be faster.... also the maxima has less tourque then yout bimmer...
anyways... chip is your best bet.. and not too exspensive..
-SOLD..
R.I.P Fast 6
Old 04-15-2005, 05:13 AM   #9 (permalink)
docrobot's Avatar
docrobot is an unknown quantity at this point
I bet that 96 Maxima wasn't stock...
docrobot is offline   Reply With Quote
power gain driftin325s 3-Series (E21, E30) 14 09-20-2005 11:24 AM
100hp Gain..... Tingtong187 M-Series (M1, M3, M5, M6) 17 08-09-2005 01:40 PM
More Horses J-iX-er 3-Series (E21, E30) 15 12-11-2004 03:26 PM
New exhaust system horsepower gain? jonshee92 3-Series (E46, E90) 1 09-15-2004 09:41 AM
