Originally Posted by jrw7714 Can the check engine light on my 2004 33oci. be reset by disconnecting the neg. battery terminal? Is there a fuse that also could be pulled to reset? I haven't run a code check yet but have cleaned the maf sensor which didn't make the light go away. Any suggestions? Car runs fine. |
as long as the code problems were fixed , disconnecting the terminal should work, about ten minutes then reconnect, let me know how things work out.
