How do I stop this Leak? - BMW Forum - BimmerWerkz.com
Old 03-21-2006, 02:30 PM   #1 (permalink)
rfthomas is an unknown quantity at this point
My radiator has a small leak. Every once and a while I have to add a few ounces of coolant. I have not been overheating. The picture I attached shows where its leaking. Can I use an additive like Bar's Stop Leak or is that a no-no? I'll be bummed if I have to replace the radiator. Any ideas???
RFT
rfthomas is offline   Reply With Quote
Old 03-21-2006, 02:33 PM   #2 (permalink)
Avlany's Avatar
Avlany is an unknown quantity at this point
Send a message via ICQ to Avlany
You cant. I am sorry to say that, but In this case you gotta replace the radiator mate.
Dont piss me off. I am running out of places to hide the bodies
<img src='http://members.dslextreme.com/users/avlany/images/BMW%20banner.gif' border='0' alt='user posted image' />
Avlany is offline   Reply With Quote
Old 03-21-2006, 03:25 PM   #3 (permalink)
tomctx's Avatar
Unless it's leaking out of the hose in the picture next to it, I'd also vote for radiator.
Old 03-21-2006, 06:07 PM   #4 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
I vote radiator. Stop leak will plug up holes within your radiator too, and possibly in your engine block, and will block the circulation holes between the radiator and the coolant expansion tank. It's a no-no.
Lindsay fan club member.
Old 03-21-2006, 07:43 PM   #5 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
great deal on radiators at bimmerzone.com $140 shipped, oem....check it out....and yea its ur radiator, hoses unless busted, dont leak like that
Old 03-25-2006, 07:50 PM   #6 (permalink)
Thanks for all the help. Looks like I'll be ordering a radiator. Should I replace all the hoses while I'm at it?
RFT
Old 03-25-2006, 09:44 PM   #7 (permalink)
tomctx's Avatar
Unless you know when they were replaced, I would suggest replacing the hoses. You are going to have them loose anyway,and probably not much more money.
Old 03-28-2006, 12:21 PM   #8 (permalink)
hst
hst is on a distinguished road
RFT
No reason not to.
hst is offline   Reply With Quote
Old 03-28-2006, 01:31 PM   #9 (permalink)
ex owner/admin
Furious's Avatar
hoses are always a good idea to change, usually the return hoses are the ones that you should change, if you can only afford to get a few. but yes the rad has to go, stop leak is a bad idea, my mechanic says it actually will clog the rad up making the flow more restricted.
Old 03-29-2006, 08:38 PM   #10 (permalink)
Laker is an unknown quantity at this point
Pinch those tabs tighter. I did this to my Dodge Ram 3 years ago and never leaked since. Use a pair of vice grips or channel locks. Worth a try its free.
Laker is offline   Reply With Quote
Oil Leak From Bottom Of Engine??? BIG 730 1,6,7,8 - Series and Mini Cooper 3 12-19-2005 02:57 PM
Fuel Leak ajreich 3-Series (E36) 1 11-13-2005 08:00 AM
Driver-side Water Leak Kellyd 1,6,7,8 - Series and Mini Cooper 3 04-20-2005 04:36 PM
Oil leak... Regnout 3-Series (E36) 21 11-07-2004 09:06 PM
home-made clutch stop woobiee Picture Showroom 7 02-11-2004 01:14 AM
