How Do I....put On My Own Wheels - BMW Forum - BimmerWerkz.com
Old 03-30-2005, 03:40 PM   #1 (permalink)
atm2000 is an unknown quantity at this point
so...... i got a new set of wheels, i can take them to the dealer and get them to take of fmy wheel, and mount my new wheels. BUT, i figure this might be a good DIY project (my second one after putting in a new air filter.)
Question: how "tight" should hte bolt be on the wheel after it's been mounted, do I need a torque wrnech to get this done properly?
atm2000 is offline   Reply With Quote
Old 03-30-2005, 04:22 PM   #2 (permalink)
tomctx's Avatar
[snapback]321757[/snapback]
I've seen quotes between 80 and 85 lb-ft of torque. And yes, you should use a torque wrench. BTW, only 5 lbs difference, pick a number.
Old 03-30-2005, 04:23 PM   #3 (permalink)
The Deuce is an unknown quantity at this point
About 90 ft/lbs is pretty standard.
I've never used a torque wrench in all my years of putting on wheels and never hurt a rim or had one fall off or wobble.
Make sure you follow the star pattern when you tighten them, and start by hand tightening them.
I go around the start 3x. Remember, you need to be able to remove one with the tools you carry in the car if you get a flat.
2002 BMW 530i
1997 Ford Mustang GT
1995 Honda VFR 750 (For Sale)
1964.5 Ford Mustang
The Deuce is offline   Reply With Quote
Old 03-30-2005, 04:25 PM   #4 (permalink)
[snapback]321788[/snapback]
yeah, i had the same idea...but i'm hearing from people a torque wrench is good to mount tires.
shit, this is the first time i'm doing it and i don't want my wheels falling off on the highway!!!!!!
how tight is the bolt? (i'm sure this is relative since we have different strengths.)
Old 03-30-2005, 04:31 PM   #5 (permalink)
[snapback]321791[/snapback]
It's tight enough. ghead If you use the wrench that came in the car, you should be able to get it tight enough. Put it this way, I pull up (against the ground like a squat) to get them off, but only push down to get them on. I'm 190 lbs, and the wrench is about 16" long, so given the co-efficient of gravity, it's close to 90/lbs I figure.
If you have a torque wrench, go a head and use it, but there's no reason to go buy one to do this.
I've been working on cars for a long time and have a feel for torque specs by now though. I've heard guys here using torque wrenchs on their spark plugs and license plates.
2002 BMW 530i
1964.5 Ford Mustang
Old 03-30-2005, 04:41 PM   #6 (permalink)
Originally posted by The Deuce+Mar 30 2005, 05:31 PM--><div class='quotetop'>QUOTE(The Deuce @ Mar 30 2005, 05:31 PM)</div><div class='quotemain'><!--QuoteBegin-atm2000@Mar 30 2005, 06:25 PM
[snapback]321796[/snapback]
[/b][/quote]
license plates and spark plugs?
Old 03-30-2005, 04:49 PM   #7 (permalink)
BaLAnCe17's Avatar
BaLAnCe17 is an unknown quantity at this point
Send a message via AIM to BaLAnCe17 Send a message via MSN to BaLAnCe17
lol use a damn torque wrench. i went to the bmw dealer and they said between 80-90. the star patern is also very important. my neibors have a new 645 and they didnt torque thier summerwheels back on and one was wobbling really bad, turns out the bolts were loose. torque them!
BaLAnCe17 is offline   Reply With Quote
Old 03-30-2005, 09:50 PM   #8 (permalink)
jshearer's Avatar
Car: 1994 325is
jshearer is an unknown quantity at this point
OK, I did this 4 days ago. In your manual you can look up the torque they require. Go by this to make sure you have exactly what is needed. Example for my 1994 325is it is 81lb/ft, for my dads 1995 M3 it is 83, and my moms 2003 530 it is 72(we changed to summer tires on all the cars in one day).
I would recommend a torque wrench(by recommend i mean definately, you never know what could happen and if something did you would be blaming yourself) and using a good jack(not the crappy BMW jack, it is alright for a flat on the road situation but not this).
The process is not that hard. The hardest part is getting your old wheels off(they can be rusted on). Simply jack up one quarter at a time, pull old wheel off, remove any rust with wire brush or steel wool, put new wheel one(following a star pattern with the lugs), torque the to specifications, move onto the next.
You should also go drive the car and retorque the wheels after a couple of miles, and then again after 500 miles on the new wheels. It is also recommended that you get an alignment after putting on wheels(especially if they are a different size).
If you have new tires on the wheels don't drive hard on them for tank of gas or so(300-500 miles). This is because of the chemicals they put on the tires to preserve them.
Good luck, let us know if you have any other questions.
<a href="http://imageshack.us"><img src="http://img217.imageshack.us/img217/3466/quicksignature20te.jpg" border="0" width="600" alt="Image Hosted by ImageShack.us" /></a>
jshearer is offline   Reply With Quote
Old 03-30-2005, 10:41 PM   #9 (permalink)
325isBaby's Avatar
Car: 2005 330xi
BMW spec is for X3, 3, 5, 6 series 120Nm (90lb/ft)
for X5, 7series 140Nm (120lb/ft)
Come see me at MySpace
Old 03-30-2005, 11:10 PM   #10 (permalink)
spieluhr's Avatar
spieluhr is an unknown quantity at this point
Send a message via AIM to spieluhr
go to les schwabb or discount tire and Im sure htey will torque them down and check air pressure at no cost.
<img src='http://img268.echo.cx/img268/1430/zkwsig23iq.jpg' border='0' alt='user posted image' />
1996 328is Black
Suspension: MB Motoring 18x8, Kuhmo Supra 225/35/18ZR
Audio:Eclipse CD3414 HU
Lighting: ZKW W/ DDE PLUS
spieluhr is offline   Reply With Quote
Old 03-31-2005, 12:17 AM   #11 (permalink)
jshearer's Avatar
Car: 1994 325is
If you are going to get an alignment I am sure the place you go will probably change your wheels for next to nothing if not free.
Old 03-31-2005, 01:38 AM   #12 (permalink)
Boxbrownie's Avatar
Boxbrownie is an unknown quantity at this point
Send a message via AIM to Boxbrownie Send a message via MSN to Boxbrownie
[snapback]322000[/snapback]
This is correct, and definatley use a torque wrench, the brace/wrench that comes with the car is for emergency use only!
Best regards David
Boxbrownie is offline   Reply With Quote
Old 03-31-2005, 09:52 AM   #13 (permalink)
93 325i's Avatar
You guys gotta be joking, you don't need a damn torque wrench.. If you have access to one, great use it. But dont go out and buy one just to put your wheels on. I have never used a torque wrench on my wheels ever and nothing ill has come of it. Just tighten them basically as tight as you can using a good lug wrench. Common sense says that they have to be on tight. As long as you use this common sense your wheels will not come flying off..
Complete mod list and pics:
My 1993 325i
Old 03-31-2005, 10:26 AM   #14 (permalink)
[snapback]322122[/snapback]
It's not brain surgery, it's a tire.
2002 BMW 530i
1964.5 Ford Mustang
Old 03-31-2005, 11:01 AM   #15 (permalink)
NeverLeaned is an unknown quantity at this point
Send a message via AIM to NeverLeaned
YOu don't HAVE TO HAVE a torque wrench to do this. When I was an apprentice mechanic, there was only one car we ever used a torque wrench on..... Mercedes. Really just because its a bolt up style then the typical car.
What I usually do is tighten them all down (make sure you follow a start pattern doing opposite sides of the wheel each time.
Then, Stand on your Wrench, and give a little ummph down.... you should move the bolt another 1/8th turn........ homemade torqueing
Good luck!
1996- BMW 328IS
<img src='http://img.photobucket.com/albums/v242/gws226/TEX/neverleanedsig.jpg' border='0' alt='user posted image' />
Performance: Zimmerman Cross Drilled Rotors-- PBR Deluxes-- Cosmos CAI---- Turner Pulley Kit--- Fan Delete mod---
Beauty: 18 polished M-Parallel replicas, Inpro Euros w/ Enchanced Angel eye kit, 20% tint
Clear corners/sidemarkers ---- Eurospec (Depos)
To do list:
Suspension--- researching
UUC System U TDM- 3/05
M50 manifold converstion 3/05
NeverLeaned is offline   Reply With Quote
545 Sport Wheels And Nitto Tires 4 Sale 98bimmerhead Wheels and Tires 1 06-07-2007 04:18 PM
Staggerd Setup Asa Ar1 Wheels Cheap!!!! muff daddy Wheels and Tires 1 09-22-2005 05:48 PM
I'm Buying New Wheels For My 3 Series E46 greglacle 3-Series (E46, E90) 4 07-11-2005 05:27 PM
Wheels For My 86 535i? October 5-Series (E12,E28, E34, E39, E60) 0 03-10-2005 07:12 PM
19x10" And 19x9" I-forged Aero Wheels For Sale!!! wildstang Classifieds Sell & Buy 1 09-27-2004 09:20 AM
