How can I wire up 2 front fogs with only one lead? - BMW Forum - BimmerWerkz.com
Old 09-27-2005, 04:23 AM   #1 (permalink)
KILOCHARLIE's Avatar
KILOCHARLIE is an unknown quantity at this point
One of my front fog light cables has been ripped out so only one of the fogs are connected up and working.
Is there any way I can somehow split the cable and wire up the other one?
Also another wire seems to have been ripped out from under my car (don't ask!) as there is nothing connected to my radiator. There is a little 2 pin socket on the bottom corner with nothing attached, although the temp gauge on my dash seems to be working fine.
There is lead in my engine bay with a black connector on the end and green / yellow cabling which isn't connected to anything, which i thought would be the radiator one, but it's about a 12 inches too short to reach the plug. It doesn't seem to be the other fog light one tho as when connected up, its the wrong type of connector and the fog light doesn't come on.
Can anyone please help???
KILOCHARLIE is offline   Reply With Quote
Old 09-27-2005, 10:16 PM   #2 (permalink)
Pandemonium Director
nukeduster's Avatar
Car: turbo 325is, 325es, Audi a4 turbo
T-tap the wire running to your other fog lights + wire and run it to the positive lead on the other fog... then run a wire from the - lead on the fog to a ground point on the chassis somewhere.
Old 09-27-2005, 10:23 PM   #3 (permalink)
Power Shifting
Cruzin 323is's Avatar
your best bet is to splice from the foglight that works...
or follow the wires back.. and re-wire it
-SOLD..
R.I.P Fast 6
Old 09-28-2005, 12:35 AM   #4 (permalink)
nukeduster's Avatar
thats what I just said. <_<
Old 09-28-2005, 08:00 AM   #5 (permalink)
thanks peeps, how do i know which wire is the positive?
also do you know anything about the radiator / other lead problem?
thanks again!
Old 09-29-2005, 04:38 AM   #6 (permalink)
Dudesky_E36's Avatar
Car: Anthracite e39 530iA
Dudesky_E36 is an unknown quantity at this point
Send a message via AIM to Dudesky_E36
Try what these guys suggested, but if you blow a fuse, then you may need a relay. BMW's are wired using seperate harnesses for left and right side of the vehicle, but I don't know if that applies to the fog lamps as well. If it does, you may end up overloading the circuit on the good side by splicing into it. If that's the case, holler back and I or someone else here will instruct on how to wire up the relay.
To find the (+) wire, you'll need a circuit tester between each wire and the car's metal chassis. Whichever lights up or shows current is your baby.
Don't know about the other wire by your radiator, sorry.
Dudesky_E36 is offline   Reply With Quote
Old 09-29-2005, 07:27 AM   #7 (permalink)
thanks man, i'm gonna hook up a simple wire tester with a bulb tonight i think.
i just checked realoem for that radiator lead and there's nothing on it.
Can anyone please tell me where the lead goes to on their e36, and what colour the wires are?
it's plugged into the bottom right hand side of the radiator.
many thanks to all that helped, esp dudesky who's gotta be the most helpful member on this site!
Old 09-29-2005, 11:26 AM   #8 (permalink)
Live Fast. Drive Faster.
buuhh99's Avatar
buuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond repute
Send a message via AIM to buuhh99
yeah it is just a random wire left there by bmw, mine has the same thing, it has a connector on the end, with two wires right, sits on the left side when u look into the engine bay, From what I concluded(by looking at the bently wiring diagrams) it was wire for the m52 engine, or for some light, as the connector is the same as the fog lights. O well the bmw technicans at my work say that it is supposed to be there so u are fine, aslong as u arnt getting any fault codes
buuhh99 is offline   Reply With Quote
Old 09-30-2005, 09:14 PM   #9 (permalink)
Alarm siren plug ?
You're not talking about the wiring plug for the alarm siren are you? It hangs out by the right front headlight. A female plug, unused unless you have a siren up there.
Mike
Hamfisted is offline   Reply With Quote
Old 10-03-2005, 06:47 AM   #10 (permalink)
thanks peeps.
do you know if the wiring is green?
Front Drive Shaft Loose On 325xi bmw_in_maryland 3-Series (E46, E90) 4 01-13-2005 06:44 AM
E46 Wire Guides (complete) EcianIce Audio and Electronics 2 09-26-2004 07:40 PM
Help wiring up amp install lude69 Audio and Electronics 13 08-15-2004 10:24 AM
Fog Light Modification E39 ViewMaster Bimmer Talk/Motorsports Talk 1 10-25-2003 11:09 PM
