Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 04-22-2004, 01:45 PM   #1 (permalink)
Photos: 0
It's a Bilstein Sport Gas strut. There seems to be no evidence of leaking oil.
Whenever I hit a small bump or even sometimes when I brake, I can hear a clunk. I don't notice anything different when cornering hard.
I've heard the "bounce" test doesn't work for the front struts. I can't feel that the front is any bouncer than before. What I do notice is when I push the passenger side front down hard I hear a "knock". There's no knock on the driver side when I do this.
Are there any other tests I can do? It only knocks when I hit bumps at low speed. At high speed no matter how hard the bumps I hear nothing at all.
It's not the CA bushings or balljoints, I've checked these things and recently they have all been replaced.
Thanks,
Bry
Old 04-22-2004, 02:03 PM   #2 (permalink)
Super Moderator
dutchbmw's Avatar
Photos: 0
When pushing on the front of your car, the car should spring back and becomes standing within 3 times. This obtains for standard struts. You're (more racy struts) might be stop undulate within 1 or 2 times. When it's more than twice, they have to be replaced.
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 04-22-2004, 02:06 PM   #3 (permalink)
Photos: 0
I just said that the "bounce" test doesn't actually work for the front struts, only the rear.
Old 04-22-2004, 03:00 PM   #4 (permalink)
Administrator
Furious's Avatar
Photos: 0
check for it leaking.
R.I.P Steve aka fast 6
Old 04-22-2004, 03:07 PM   #5 (permalink)
Photos: 0
It's not leaking. I checked.
Anyways, I noticed this after I installed my brakes. Do you think my caliper or brake pads could be seized, does this make noise?
thanks,
Bry
Old 04-22-2004, 03:14 PM   #6 (permalink)
Eggrolled211's Avatar
Photos: 0
Eggrolled211 is an unknown quantity at this point
Maybe your aftermarket springs are too low,Not allowing enough tube slack/travel etc. hence bottoming out? I dunno
<img src='http://l00062.myspace.com/00062/50/89/62019805_m.jpg' border='0' alt='user posted image' />
Eggrolled211 is offline   Reply With Quote
Old 04-22-2004, 03:18 PM   #7 (permalink)
Photos: 0
They're only Eibach pro kits. Bilstein Sports work fine with those. It wouldn't be bottoming out.
I just need to know how else I can test for a blown strut.
Obviously I could remove it and press it down to test it that way. But I don't have the right tools to remove the springs.
Bry
Old 04-22-2004, 03:18 PM   #8 (permalink)
Administrator
Furious's Avatar
Photos: 0
caliper sieze will give more of a feeling than a sound.
Old 04-22-2004, 03:22 PM   #9 (permalink)
Photos: 0
Dammit, I'm heading to Charlie's tonight. I'll get him to help me.
Mark, I'm returning the spring compressor, you don't need it anymore right?
Bry
Old 04-22-2004, 03:45 PM   #10 (permalink)
Super Moderator
dutchbmw's Avatar
Photos: 0
A weared out brake pad....... or suspension rubber?? Sure it is a strut?
BMW '96 M3 (SOLD)
Old 04-22-2004, 04:35 PM   #11 (permalink)
6th Gear Member
Kevin325i's Avatar
Photos: 0
Check the screw on top of the shock that attaches it to the mount, it might have worked its way lose. Should be right at the top of the shock towers.
I get that same clunk in my jeep and it's cause the shock is loose, but the area is too tight for me to get a wrench in and the jeep is a POS anyways, so I figured what the hell, I can deal with it.
Kevin
Kevin (President TBEA)
Old 04-22-2004, 07:05 PM   #12 (permalink)
Fox
Moderator
Photos: 0
Send a message via ICQ to Fox Send a message via AIM to Fox Send a message via MSN to Fox
Ok get this its not your strut. Its one of two things.
This is what it most Likely is, Id put $20 on this.
Your upper strut bearing is SHOT. This are plastic POSes and they need to be replaced every so often. Its like 200$ for a mechanic to do this, dont waste your time yourself becaue yo have to compress your springs and all that shit and unless you have the tools that pretty dangerous.
And this is an alternate choice: Your actual caliper mounting is loose from the bracket. This has happened to me 3 times in the last 4 months. It makes a clink sound as you brake at low speeds.
And thats the facts Jack.
Fox is offline   Reply With Quote
Old 04-22-2004, 08:00 PM   #13 (permalink)
Super Moderator
jllphan's Avatar
Photos: 0
Maybe its the balljoints. Sorry, everyone else was suggesting things you have already mentioned you have checked, I just wanted to play too!!
Old 04-22-2004, 08:32 PM   #14 (permalink)
Photos: 0
Sorry, you guys are all wrong! LOL Seriously, thanks for all the replies though.
I went to my mechanic's house today and it turned out that the M3 sway bar endlink bushing was worn, so it was making a clunking noise. The endlink had metal to metal contact. I had a feeling it wasn't my strut as it still felt quite firm. When I cornered hard the right side would hop so I suspected it was sway bar related. I installed the M3 sway last weekend and installed used endlinks along with it. I should have bought new ones. DOH!
Anyways, I'm happy.
Just a note.. normal E36 front sway bar endlinks almost never break and more or less last forever. However, the M3 front sway bar which is mounted to the struts use a really long endlink which is a common failure.
Bry
Old 04-22-2004, 08:39 PM   #15 (permalink)
6th Gear Member
Kevin325i's Avatar
Photos: 0
We all lose
Kevin
vB code is On
Proper Torque Lbs For Front Strut Stress Bar bob1998ic 3-Series (E36) 0 05-06-2005 03:08 PM
***wanted***m3 Dinan Rear And Front Strut Bars bmwforumerm3 Classifieds Sell & Buy 0 03-10-2005 10:16 PM
E36 Front Strut Tower Brace uber e36 Classifieds Sell & Buy 0 09-14-2004 11:31 PM
My Bilstein front strut has tabs Autotechnica 3-Series (E36) 10 04-15-2004 06:44 PM
e39 Front Strut Brace bmwboy5series 5-Series (E12,E28, E34, E39, E60) 2 02-22-2004 04:08 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
