how can i fix my door? - BMW Forum - BimmerWerkz.com
Old 01-18-2006, 10:08 AM   #1 (permalink)
polaris448's Avatar
polaris448 is an unknown quantity at this point
My left door keeps getting harder and harder to close. i almost have to slam it to get it to shut. the window goes up and down as it should but it is. i feel like i am going to break the inside panel off of the door sometimes. any suggestions?
polaris448 is offline   Reply With Quote
Old 01-18-2006, 10:45 AM   #2 (permalink)
quality
Delmarco's Avatar
Spray the hinges with WD40.
Old 01-18-2006, 11:09 AM   #3 (permalink)
Power Shifting
Cruzin 323is's Avatar
some lube should work..
-SOLD..
R.I.P Fast 6
Old 01-18-2006, 11:15 AM   #4 (permalink)
tomctx's Avatar
If the lubing doesn't work, close it slowly and check to see if it's out of alignment.
Old 01-18-2006, 02:17 PM   #5 (permalink)
Linds's Avatar
Linds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond repute
Send a message via AIM to Linds
Isn't WD40 a degreaser? Which would be the opposite of what he should use?
Coming soon...
Linds is offline   Reply With Quote
Old 01-18-2006, 02:23 PM   #6 (permalink)
SpooldUp's Avatar
Car: 99 323i ragtop
SpooldUp will become famous soon enoughSpooldUp will become famous soon enough
Send a message via AIM to SpooldUp
WD40 it first, then try aligning the striker mounted to the frame where the door lacthes. the latch also had a little adjustment in it. i think you should use torx bits, but metric allen keys will work.
'99 323i 5spd
<CENTER>
</CENTER>
where's my beer?
best website ever
"I'm not even supposed to be here today"
SpooldUp is offline   Reply With Quote
Old 01-18-2006, 09:37 PM   #7 (permalink)
tomctx's Avatar
Printed on the back of a WD-40 can: It lubricates, it cleans, it protects, it penetrates, it displaces moisture. WD means water displacement, what it was originally intended to do, the 40 is the 40th mixture which worked. It does have a lubricant in the can. How good it is and how long it lasts, I have no idea.
Old 01-18-2006, 11:52 PM   #8 (permalink)
Power Shifting
thats exactly right...
and it works wonders...
-SOLD..
R.I.P Fast 6
Old 01-19-2006, 06:34 AM   #9 (permalink)
quality
Delmarco's Avatar
wd-40.
why is this getting complicated...?
Old 01-19-2006, 07:43 AM   #10 (permalink)
ex owner/admin
Furious's Avatar
god what is with WD-40, besides the inexpensiveness and avaliblity.... there are much better lubricants out there that do the job better and last longer... try lubricating the door, if it doenst help much , id look into replacing the door pins, they do wear out and make closing the door a pain (heheh my drivers door has been like that for a while)
Old 01-19-2006, 12:05 PM   #11 (permalink)
cymorg's Avatar
cymorg is an unknown quantity at this point
Send a message via ICQ to cymorg Send a message via AIM to cymorg Send a message via MSN to cymorg Send a message via Yahoo to cymorg
my passenger side has similar problems...
i just make my passengers re-close the door until they get it right, lol
i think my problem may have to do with the rubber seal that goes around the door, though. i think it might be off-track a little. you may look into that.
cymorg is offline   Reply With Quote
Old 01-21-2006, 03:31 AM   #12 (permalink)
polaris448's Avatar
i have replaced the door pins on a different vehicle and will never do that again. it was a pain in the ass. lube does nothing. (WD-40 is the worst stuff for door pins, it evaps in like 5 min) i will try to move the striker around. i just feel when i shut the door sometimes that the whole panel is going to separate from the door frame. thanx for ur input.
E36 Door Panels Switched!!!! Delmarco 3-Series (E36) 3 06-10-2005 09:12 AM
Door Situation hnhan 3-Series (E46, E90) 2 04-08-2005 04:33 PM
Solution to Door Edge Seal Problem zulkhernain 5-Series (E12,E28, E34, E39, E60) 4 09-16-2004 09:24 PM
X5: 0-60 in 4.0 tcpgv 1,6,7,8 - Series and Mini Cooper 6 03-30-2004 02:51 AM
What do you guys do about door panels? Ronny 3-Series (E36) 3 01-17-2004 09:08 PM
