horn doesn't work - BMW Forum - BimmerWerkz.com
Old 03-28-2004, 07:53 PM   #1 (permalink)
jaws325's Avatar
jaws325 is an unknown quantity at this point
Hey...my horn doesn't work...If I ground the relay it works.must be a bad ground or with my luck the 'horn switch'.....anybody know how to test the switch?
jaws325 is offline   Reply With Quote
Old 03-28-2004, 08:08 PM   #2 (permalink)
TECH's Avatar
The "switch" in the steering wheel IS the ground for the relay. Maybe the steering column isn't grounded well, I've seen that on older cars.
If you remove the airbag, you'll see all the wiring behind it. The horn ground is one of them, but I'm not sure of the color-probably the same as the relay control.
Old 03-28-2004, 08:35 PM   #3 (permalink)
jaws325's Avatar
is the airbag easy to get off? any danger of messing it up (like blowing up in my face?)
Old 03-29-2004, 12:35 AM   #4 (permalink)
Defector
El Presidente's Avatar
by an electronic air horn and rig that. You can buy one with sirens and big-rig horn for like $30. Its on my list of wants......
Old 03-29-2004, 05:54 AM   #5 (permalink)
Super Moderator
dutchbmw's Avatar
Ask someone who can work with a electrical Ohm gauge (is this the right word??), and you'll know within a few minutes what the reason is for the not working horn.
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 03-29-2004, 07:05 AM   #6 (permalink)
ex owner/admin
Furious's Avatar
ohm meter, ohm gauge, same thing.
Old 03-29-2004, 07:14 AM   #7 (permalink)
jaws325's Avatar
I have no problem buzzing out the circuit, only thing that scares me is taking off the airbag.....hey, what is the worst that could happen..my airbag deploys but at least I'll fix the horn..I thought of adding an air horn but would prefer to to fix mine.
Old 03-29-2004, 08:32 AM   #8 (permalink)
Super Moderator
dutchbmw's Avatar
Thanks furious for your help....
Jaws325:
When you buzzing out the circuit, you can disconnect the wire at the relay that comes from the steering wheel. Than connect your ohm meter and push at the horn (on the steering wheel). The ohm meter should give you the value of 0. This means, no resistance in that circuit, so there is nothing wrong with the contact in the steering wheel!
When only doing that, the airbag should not come out, yet?? So i do not comprehend why worry about that stupid airbag!
BTW: welcome at the forums!
BMW '96 M3 (SOLD)
Old 03-31-2004, 09:22 AM   #9 (permalink)
jaws325's Avatar
Thanks for the tips I'll work on this weekend..
Old 05-07-2004, 12:27 PM   #10 (permalink)
jaws325's Avatar
Old 05-07-2004, 12:28 PM   #11 (permalink)
jaws325's Avatar
Old 05-07-2004, 03:31 PM   #12 (permalink)
Super Moderator
dutchbmw's Avatar
Weekends are over, does it work yet?
BMW '96 M3 (SOLD)
Old 05-07-2004, 03:40 PM   #13 (permalink)
jaws325's Avatar
I buzzed it out and there is a break in the slip ring or the clock spring as some call it ( the ribbon cable in the steering columb) ...$295 CDN at the dealer and $100CDN from a bone yard..
I'll get a blow horn to blast the daydreamers on their cel phones till I change it.
thanks again...
Old 05-08-2004, 12:43 PM   #14 (permalink)
Threadkiller
bitcore's Avatar
Check out this thread if you wind up running more wires or something...
Pritty soon I'm gonna make the regular horn button do both horns [much louder + sounds like a train], and leaving my new button alone so it only triggers the additional horn.
I can't wait to sell this car and see what they do when they press the button
1999 E46 (328i sedan) and the radio will not work. abalto 3-Series (E46, E90) 1 08-04-2004 10:57 PM
some interior lights dont work protomor 3-Series (E21, E30) 6 06-18-2004 12:13 AM
clutch still doesn't work 635csiluver 3-Series (E36) 2 09-22-2003 11:52 PM
