Hood Release - BMW Forum - BimmerWerkz.com
Old 10-17-2004, 06:47 PM   #1 (permalink)
Defector
El Presidente's Avatar
Its jammed shut. Any suggestions on how to open it? Pics:
http://www.bmw-forums.com/forum/inde...howtopic=24279
Old 10-19-2004, 01:07 AM   #2 (permalink)
Defector
No one?
Old 10-19-2004, 01:26 AM   #3 (permalink)
///M3 FX's Avatar
///M3 FX is an unknown quantity at this point
Send a message via AIM to ///M3 FX
Im thinking!
///M3 Cc #47
<img src='http://www.sfxradio.net/Brad/them.jpg' border='0' alt='user posted image' />
Current: 97 ///M3 Estroil Blue Coupe/Manual
Sold: 98 ///M3 Cosmos Black Cabrio/Auto
///M3 FX is offline   Reply With Quote
Old 10-19-2004, 01:30 AM   #4 (permalink)
///M3 FX's Avatar
have you tried getting a screwdriver up there and unlatching it manually?
Its not gunna be good if you broke the latch inside the clip =x
///M3 Cc #47
Old 10-19-2004, 01:39 AM   #5 (permalink)
llzoom_zoomll is an unknown quantity at this point
Send a message via AIM to llzoom_zoomll
well, i bought my e36 damaged from the front, so i kinda know what ur goin through. I had repaired a front end collision on another e36 so i knew how the hood latch worked. The one thing i can think of is to stick a flat screw driver between the hood and the catch (yes catch...the round thing the pins go into) and pry it open. you will most likely have to change the two catches on the front, their mechanism most likely have gone bad. i changed mine from a parts car i had, but, i was told they are within $50 bucks for both at the dealer. oh, and i forgot to mention, if you get someone else to help you, have them push down the hood, while you pull the handle, and give it a nice healthy tug upwards to get it open. sorry for makin this long, hope it helps...
lemme kno wut happens, and if u get time, what are ur plans...
You think gas is expensive? CHECK THIS OUT:
Lipton Ice Tea 16 oz $1.19 ...........$9.52 per gallon
Ocean Spray 16 oz $1.25 .......... $10.00 per gallon
Gatorade 20 oz $1.59 ..... $10.17 per gallon
Diet Snapple 16 oz $1.29 .......... $10.32 per gallon
Evian water9 oz $1.49..........$21.19 per gallon?
Brake Fluid 12 oz $3.15 ........... $33.60 per gallon
Pepto Bismol 4 oz $3.85 ........ $123.20 per gallon
Vick's Nyquil 6 oz $8.35 .... $178.13 per gallon
llzoom_zoomll is offline   Reply With Quote
Old 10-19-2004, 01:42 AM   #6 (permalink)
94 325is's Avatar
94 325is is an unknown quantity at this point
Send a message via AIM to 94 325is
from the look of it you may have to pull the grill back out some for the latch to release
94 325is is offline   Reply With Quote
Old 10-19-2004, 01:42 AM   #7 (permalink)
///M3 FX's Avatar
Does the hood release cable feel like it is releasing the latch?
have you tried to open the hood with a helper or just yourself? With two people, one of you pulls the hood release cable and holds it open while the other tries to open the hood. If there seems to be some movement but doesn't open....continue holding the cable release while the other person takes like a shop towel/grease rag, whatever name you know it by....run it thru the hood handle...this gives you extra "pull" and start pulling hard or jerking....if the hood release is partly jammed, that jerking movement will sometimes break the latch free. try that, mgiht just need a lil help since the lady turned your front end into scrap metal.
Edit I just realized i said the same thinghe said above lol.
Ill go out and take a look after it stops raining to see if theres a way to get the release.
///M3 Cc #47
Old 10-19-2004, 01:46 AM   #8 (permalink)
also a quick tip, the actual lockin part on the catch is on the driver side...so if you pull the hood towards the passenger side, and up, it might help a bit more. these BMW latches are made not to be broken into, so its gets tough
Old 10-19-2004, 02:09 AM   #9 (permalink)
Defector
im debating leaving it alone or opening it so I can inspect my projectors and radiator neck. I'm going to a body shop tomorrow, maybe they can get it. When I pull on the hood release, it feels like a lot of strain on the cable. No pop
Old 10-19-2004, 02:14 AM   #10 (permalink)
///M3 FX's Avatar
[snapback]213934[/snapback]
Not good might have bent it. Are you lookinf at a new hood anyway ?
///M3 Cc #47
Old 10-19-2004, 02:22 AM   #11 (permalink)
phenom is an unknown quantity at this point
Send a message via MSN to phenom
Originally posted by ///M3 FX+Oct 19 2004, 01:14 AM--><div class='quotetop'>QUOTE(///M3 FX @ Oct 19 2004, 01:14 AM)</div><div class='quotemain'><!--QuoteBegin-El Presidente@Oct 19 2004, 01:09 AM
[snapback]213937[/snapback]
[/b][/quote]
I had the same problem. Try what ///M3 suggested; get a helper. One person releases on the handle the other person pulls up on the hood. Thank good that worked for me.
phenom is offline   Reply With Quote
Old 10-19-2004, 02:27 AM   #12 (permalink)
if your worried about the strain on the cable, i really dont think its that weak! I put alot of strain on mine to open it, and one time, it clicked and gave me a chance to pull it open, but needed to pull it hard! im sure you can get it, and the most that seems to have happened, from the picture, is your radiator support might have bent, which can sometimes be bent back. if you need to replace it, its no more then 35 bucks from a parts store.
Old 10-19-2004, 02:38 AM   #13 (permalink)
Defector
waiting to go to body shop tomorrow. all I have committed to so far is a new lens for the projector.
Old 10-19-2004, 08:07 PM   #14 (permalink)
kamikazinyc's Avatar
kamikazinyc is an unknown quantity at this point
Look on the bright side, now you can use a 96+ grill plate instead of what you got the thin one.
DREMEL is South Africa Engineer's best friend
<span style='color:blue'>HID all the way </span>
kamikazinyc is offline   Reply With Quote
Old 10-19-2004, 08:22 PM   #15 (permalink)
Look at this I think this is the same as yours not the new type.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW
Hood Release Lever Pops Out - E39 540i meditek 5-Series (E12,E28, E34, E39, E60) 2 09-01-2005 07:58 AM
Hood Release bxchulo69 3-Series (E21, E30) 3 04-01-2005 05:21 PM
Help please...HOOD RELEASE REPLACEMENT lt247 3-Series (E36) 2 07-06-2004 10:33 PM
93 318is hood release katt2u 3-Series (E36) 0 05-26-2004 11:41 AM
manual hood release e30garage 3-Series (E21, E30) 3 09-06-2003 03:19 PM
