unscrew the front part of the heat protection sheet under your hood and you'll find the two rubber gromets holding your emblem. push up the protruding metal part of the emblem using a screw driver. the emblem should pop out. if your gromets have been worn out, it might be wise to change it as well.
prying the emblem from atop your hood involves a risk of scratching your paint which can ba a
ghead
