Fuel Pump ????
This is what I just read about fuel pumps I guess this will be my next and last part replacement and hope my prayers are answered. 0
Remember, the purpose of a fuel pump is twofold:
It pushes (or pumps) fuel from the gas tank to the fuel injector or carburetor.
It creates the proper amount of pressure (low or high) to ensure that the right amount of fuel will be delivered to the engine, regardless of external conditions.
Therefore, malfunctions in the fuel pump can result from an issue in either one of these processes. Let’s take a look at the common signs of these problems.
1. The Engine Sputters at High Speed
The most common early sign of a problem with a fuel pump comes when driving a vehicle at a consistent high speed. While traveling down the road, the car will run well for about 10 miles and then begin to jerk around, or sputter, for a mile or two before returning to normal.
What This Means
Many people will mistakenly diagnose a sputtering vehicle as one with "dirty" gas or some other fuel-related issue. And while that can be the case, it is not uncommon for a fatigued fuel pump to create this same symptom as it struggles to supply a constant stream of fuel to the engine at the proper pressure. The loss of pressure causes the engine to sputter.
2. Vehicle Loses Power While Accelerating
The feelings generated by this second symptom are very similar to the first. However, rather than experience a sputtering sensation while driving, vehicles will experience it upon acceleration from a stop. Generally, the vehicle will initially move before making noises and jerking around as if it will stall. Then, it will continue on its acceleration path smoothly.
What This Means
The process of acceleration creates an increased demand for fuel by the engine. A malfunctioning fuel pump, again, cannot maintain the required pressure to deliver this fuel in a steady manner, thereby causing the engine to improperly mix fuel and air and lose power. Once pressure is restored, the engine is able to run smoothly and the car takes off.
3. Sudden Loss of Power When the Vehicle Is Under Stress
A car or truck is put under stress when the work needed to complete an ordinary task, such as forward movement, is somehow hindered by external forces. Generally, this occurs when climbing a hill or when hauling a load. If, when completing these tasks, the vehicle loses power, cannot accelerate, or begins to sputter, the fuel pump is a possible culprit.
What This Means
Generally, a fuel pump, even an aging one, can maintain a steady stream of fuel and pressure when operating under normal conditions. However, once put under stress, the weakening elements of the pump will begin to take control and the fuel delivery will not be able to keep up with its demands, leading to power loss.
4. Surging
The opposite effect of the above symptoms, surging, can also be a sign of a malfunctioning fuel pump. A car that surges will be moving along normally at a consistent speed. Then, with no driver intervention, will pick up and "surge" forward, as if the gas pedal had been depressed.
What This Means
This is something that many people will mistakenly blame on the fuel filter since it is not "like" any of the other fuel pump malfunction signs. However, this surge is created because, as a result of age and normal wear and tear, the fuel pump now has irregular resistance within its motor. This creates a situation where the pump cannot draw enough electricity to maintain the pressure needed for steady speeds and may "surge" with a sudden ratcheting up in pressure.
5. The Engine Will Not Start
The final symptom of a malfunctioning fuel pump is also the most severe. Drivers who ignore the signs listed above will all eventually end up here. When a car or truck’s engine will not start as a result of a fuel pump malfunction. Basically, the engine will rev, but it will not catch.
What This Means
When a fuel pump has malfunctioned to the point that the car will no longer start, this means that there is no fuel reaching the engine upon ignition. For that reason, drivers will hear the sparks try to ignite, but there will be no fuel to burn. To diagnose a fuel pump malfunction, check for a blown fuse and pressure in the fuel line (it will be 0).
Conclusion
As an essential element of any internal combustion engine system, the fuel pump is one of those automotive issues all drivers need to keep in mind. Like any aspect of vehicle operation, understanding what a fuel pump does and the different ways that it can fail can help drivers avoid bad situations with a failing car or truck. With the important tasks of delivering fuel to the engine as well as maintaining a consistent stream of pressure while doing so, a malfunctioning fuel pump will present in several ways.
The 5 most common symptoms of a malfunctioning fuel pump include sputtering at high speeds, loss of power during acceleration, loss of power to the vehicle while under stress, surging, and, finally, an engine that will not start. Understanding these symptoms and correctly identifying them early is the only way that drivers can avoid getting to the point where their vehicle will not start, stranding them and costing a lot of money in repairs.
