High Pitched Rattling In Front Wheel Well - BMW Forum - BimmerWerkz.com
Old 05-06-2005, 06:48 AM   #1 (permalink)
Cannon00000 is an unknown quantity at this point
I hear a high pitched almost squeaking like rattling coming form my drivers side front wheel well. It does get louder over any kind of uneven surface. A buddy who knows a little more than I do told me that It was probably some kind of lose clip that holds the brake pads in place? Any ideas what this might be?
Thanks
Cannon00000 is offline   Reply With Quote
Old 05-06-2005, 07:51 AM   #2 (permalink)
CiscoKid's Avatar
that happened to me on my rear brake pads, one of the clips was broken and it was rattleing. It is very easy to check it out yourself
you can just take the wheel off, and play around with the pad, if it moves... then you need new pads, but if it doesnt wiggle at all, then its something else
Old 05-06-2005, 11:21 AM   #3 (permalink)
RIBEMR26's Avatar
Could be caliper anti-rattle clip...also, im thinking maybe hub bearings?
Clear Corners and Sidemarkers
A question for 528i front wheel bearing bigbowl 5-Series (E12,E28, E34, E39, E60) 2 08-06-2004 05:33 PM
Noise coming from front right wheel kkevin77 3-Series (E46, E90) 3 04-20-2004 06:57 PM
Larger rear wheel setup, smaller in front. Graphic Designer Bimmer Talk/Motorsports Talk 0 04-01-2004 10:59 AM
Another worthy competitor to the 3-series? AZ325Ci Other Rides 9 10-23-2003 06:08 PM
