Hi guys my car steering wheel shakes really hard at speeds of 50 what could that be? - BMW Forum - BimmerWerkz.com
Old 06-11-2011, 09:44 AM   #1 (permalink)
Car: 1993 BMW 325I
mr12gz is on a distinguished road
hI GUYS I'M NEW TO THIS AND IM TRYING TO GET MY 1993 BMW GOING GOOD
I JOINED THIS FORUM TO GAIN MORE BMW EXPERIENCE. NOW I HAVE ONE MAJOR PROBLEM MY STEERING WHEEL SHAKES REALLY BAD AT SPEEDS OF ALMOST 50 AND UP AND I DONT KNOW WHAT I SHOULD CHECK PLEASE ANY ADVICE IS APPRECIATED.
mr12gz is offline   Reply With Quote
Old 06-11-2011, 09:52 AM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
First - Please turn your "Caps Lock" Off... LOL
Between 50-60 mph everytime you drive and is never different...
Wheel Balancing !
If you have all the wheels balanced and this "wobble" still occurs then it is either the Rack, tie-rod ball joint or warped disc...
Hope This Helps (HTH)
DAZ
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 06-11-2011, 10:49 AM   #3 (permalink)
Car: 1993 BMW 325I
thanks i am going to try this and see what happens. i have another question my car seems to screech even when im not braking sometimes could that be my rotors ?
Old 06-11-2011, 06:56 PM   #4 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
Let us know what you end up finding so that others can use your experience.
Riding in style
Old 06-12-2011, 05:46 PM   #5 (permalink)
Clinton_SPX is on a distinguished road
Round
Jack the tire off the ground and spin it by hand. Make sure the tire is still round. Do this for both fronts.
Clinton_SPX is offline   Reply With Quote
Old 06-13-2011, 06:59 PM   #6 (permalink)
Car: BMW E36 318is
TRIsideRyder is on a distinguished road
could be go and get them redone or get new ones and while your there look at your brakes!
L0w
TRIsideRyder is offline   Reply With Quote
Old 06-17-2011, 04:57 PM   #7 (permalink)
Atrophik is on a distinguished road
You probably need an alignment, but if that doesn't fix it, have your wheel bearings checked. I had an issue in my 350Z with the rear wheel bearings. The rear passenger side spindle was all kinds of messed up because the bearing went out. The whole wheel would rock back and forth if you pushed on it while it was jacked up. The whole car vibrated a bit when I reached 60 or so. It ended up pressing the Brembo caliper into the rotor causing a screechy rubbing noise at higher speeds. It also dug a full circle into the rotor. Hard to miss if this is your issue. Just jack it up so the tire is a couple inches off the ground and put one hand on the top and bottom of the tire. Push the top, pull the bottom. And vice versa.
I doubt it's flat spots in the tires, since you'd probably notice that at any speed. Could be low tire pressure though.
Just for the sake of being thorough, make sure all of your lugs are tight.
Anywho, those are my ideas. Good luck.
Atrophik is offline   Reply With Quote
Old 06-17-2011, 05:53 PM   #8 (permalink)
Ya, I doubt a tire would get a flat spot also because an inflated tire would have pressure pushing out. So a tire would get a bulge as they break down and go bad.
Old 06-18-2011, 02:13 AM   #9 (permalink)
AliceFeatherson is on a distinguished road
As you're guys talkinga bout the wheels, in my opinion alloy rims with 3" of tires are looking so cool.
used cars
AliceFeatherson is offline   Reply With Quote
Old 06-18-2011, 09:20 AM   #10 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
This could be either the rotors or dodgy pads...
Jack her up and spin a wheel or two and listen for "grating"?
By this I mean notice if the pads are catching the rotors unnaturally...
If yes then its either a dodgy pad or two or...
Warped rotor.
Pads may need some copper grease on their rears.
Wheel bearing.
Just a thought mate...
Eso es todo!
BMW Part Market
New Member ?
Old 08-13-2011, 02:38 PM   #11 (permalink)
abraham130 is on a distinguished road
hello guys,can someone teel me how to remove the old wiper switch wit new one please
abraham130 is offline   Reply With Quote
Old 08-13-2011, 02:40 PM   #12 (permalink)
i think one of your wheel brake pad need change coz dat as happen to my bmw 3 series b4 and i had to change the brake pad and brake shoes.
Old 08-13-2011, 11:07 PM   #13 (permalink)
Car: 1999 e36 316i compac
morphidis is on a distinguished road
I've got oval tires that the Tyre shop doesn't want to know about it shakes hard under brakes and wobbles at 70kph its only two mill out tyre shop is blaming the rims (bloody good years)swap front for rears and see if it gets better
morphidis is offline   Reply With Quote
Old 08-14-2011, 10:36 PM   #14 (permalink)
/Banned
Car: 99 mustang
Randyboyy is on a distinguished road
According to my opinion,
actually steering wheel shakes has been a problem ever since i bought my car, the steering wheel shakes at all speeds.
What do you think of it......?
Randyboyy is offline   Reply With Quote
Old 08-24-2011, 08:38 PM   #15 (permalink)
/Banned
Car: 2009 BMW 528i
kyled is on a distinguished road
You most likely need a front alinement! and fast. Driving with off balance tires can me very dangerous and will lead to more serious problems. Take your BMW to your local BMW dealer as soon as possible.
kyled is offline   Reply With Quote
Steering Hard adamiani 3-Series (E46, E90) 1 11-21-2010 03:41 PM
Power Steering Noise When Turning Steering Wheel musclecarenvy 3-Series (E46, E90) 4 04-09-2010 06:06 PM
540i shakes badly and left front wheel HOT wayned 5-Series (E12,E28, E34, E39, E60) 6 03-23-2010 07:48 AM
steering in my 330ci shakes out of control after about 30 to 40 minutes driving PR bimmer 3-Series (E46, E90) 3 12-10-2009 05:40 PM
Car Shakes At High Speeds. Wasup?! swift707 3-Series (E36) 8 10-06-2004 04:43 PM
