HELPP HOW DO I GET THIS WHISTLING SOUND TO GO AWAY? 1997 BMW 318i - BMW Forum - BimmerWerkz.com
Old 05-22-2008, 08:21 PM   #1 (permalink)
aaltamriano is on a distinguished road
Question HELPP HOW DO I GET THIS WHISTLING SOUND TO GO AWAY? 1997 BMW 318i
I have a 1997 BMW 318i (auto) and everything on it runs Perfect but when idling a whistling sound starts and when i give it gas it goes away??? it hasnt proven to effect preformance but is EXTREAMLY ANNOYING.
a friend said it is probably the way the throttle is positioned but id rather get some advice from BMW owners be for starting to take apart anything.
Any help would be appreciated.
Thanks ALOT !
Adrian
aaltamriano is offline   Reply With Quote
Old 05-23-2008, 07:24 AM   #2 (permalink)
Nick_318is's Avatar
Car: 1991 318is, 2005 Subaru Legacy GT
Nick_318is is on a distinguished road
Send a message via AIM to Nick_318is
exhaust leak?
Originally Posted by yammahamma View Post
If I wanted to date you, I would have bought you dinner first.
Nick_318is is offline   Reply With Quote
Old 06-07-2008, 07:58 PM   #3 (permalink)
Car: 1997 138i
pete september is on a distinguished road
Crankcase Ventilation Valve (CCV), (PCV)
I just had the same whistling problem My crankcase ventilation valve (CCV) went bad. THis valve performs the same function as a positive crankcase ventilation (PCV) Valve on other cars. When I removed the valve, the small poppett in the middle fell out. The new valve had no loose parts and did not rattle like a traditional PCV valve.
The CCV BMW part number 11 15 7 501 567. I got mine at Bavarian Autosport and they also sell the molded hose that goes from the CCV to the crankcase vent if needed.
The CCV is on the rear top center of your engine it is round and has a hose attached that leads to the crankcase vent. The hose may be shrinkwrapped to another hose to keep it from rubbing on a bracket, so checking the hose may be difficult. I cut the shrinkwrap off. The valve is attached with two 5mm hex screws access will be tight. Remove the valve, turn it over and check the valve. It should look like the CCV on the Bavarian Autosport website. If the white plastic tri wing in the center is missing or damaged, it's bad.
It's that tri wing in the center that comes loose and causes the whistling. As it rattles about, it wears down the tri wings. Check the CCV before you spend any money. Be careful with the hoses, if the hose tears you can use a hose from you local parts store temporarily since it's not a radical bend. I don't know how a substitute hose would hold up to crankcase gases over the long term and it may rub on the top aft center engine bracket. Hope this helps.
If it whistles a any top 40 tunes, I know a good talent scout.
Take care, Pete
pete september is offline   Reply With Quote
Old 06-07-2008, 10:19 PM   #4 (permalink)
Bimmer M.D.'s Avatar
Car: Calypso E36: HID/A.E/6000K/18" Rims
Bimmer M.D. is on a distinguished road
Sounds like either one or more of the hoses are loose, or one or more of the hoses has a leak. You should get that checked out by a mechanic. It may also be related to the PCV Valve, an easy and inexpensive fix ($5 - $15; 3 minutes)
** FOR SALE NOW! ** 1 Day Left! ** Click Picture! **
Bimmer M.D. is offline   Reply With Quote
Old 08-23-2008, 08:42 PM   #5 (permalink)
tastoll is on a distinguished road
i had a whistling noise but it was constant. Discovered that the ac pulley was bad and replaced.
tastoll is offline   Reply With Quote
Please help........i m getting weared sound when i press break in my BMW 318i Auto Nitin_BMW318i New Members Check In 2 05-26-2006 12:56 AM
Buying 1997 Bmw 318i - Need Your Help! newbmw 3-Series (E36) 7 09-06-2005 08:04 PM
Help: Loud Whistling Sound On E36b oe_tuning 3-Series (E36) 8 12-06-2004 04:21 AM
Bmw 2004 330ci Whistling/whinning Noise sanai79 3-Series (E46, E90) 4 11-05-2004 11:48 PM
whistling sound from back sanai79 3-Series (E46, E90) 2 04-27-2004 12:38 PM
