| Its so easy..theres only 2 nuts holding the calipers. I think 15 or 17. Just loosen them two and it'll fall out. My left brakes had the sensor,just be sure not to let the heavy caliper drop and yank the sensor off. the sensor can be removed very easily and put back on. etc. the rightside of my car didn't have a sensor just the left drivers... I didn't have to bleed nothing. I use a rubber part of the wrench or whatever I can use to push/pry the cylinder back in order to put new pads on and put onto the rotor....Sorry kinda confusing but I'm at work....The job took me about 25mins each side...very easy to do...saved $$$$
__________________ <img src='http://l00062.myspace.com/00062/50/89/62019805_m.jpg' border='0' alt='user posted image' /> |
