Originally posted by RIBEMR26@Feb 15 2005, 06:28 PM Quick bump for the night shift...see if anyone has any ideas....I searched around and read that the most common reason for this is apparently the non-return valve? Can anyone help me out with some details around exactly what this part is...is it a part of the air pump? [snapback]292530[/snapback] |
part of the air pump system. Located on the exhaust manifold. Common failure part, pull the hose off of it and check inside with a mirror somtimes they get clogged with carbon.
pull the other end of the hose off(connected to the air pump) if water comes out of it replace the pump, valve and reset the light and take the car on a nice ride to make sure it doesn't reset. If you need any help...email
Steve
