Help!!! Several Questions To Ask... - BMW Forum - BimmerWerkz.com
Old 04-21-2005, 10:34 PM   #1 (permalink)
BMN247 is an unknown quantity at this point
Arrow
Hi, need help to find the answers to this questions. i own a 318i 1993 E36.
1. get a rear left "whoop whoop" when speeeding up.....then goes slightly at regular speed but returns when i slow down.. i just got new 18" rims..the sound went softer but now its back...its bloody annoying..
2. light in the instrument cluster is on..looks sumthing like this (O) (if i remember correctly). i think it might be related to the problem above.
3. i also sometimes get a petrol smell in the cabin when starting the car (intermittant problem)
If someone could help me with these problems it would be much appreciated!!!
Cheers!!
BMN
BMN247 is offline   Reply With Quote
Old 04-21-2005, 11:06 PM   #2 (permalink)
RallyE36 is an unknown quantity at this point
Cheers!!
BMN
[snapback]336286[/snapback]
1- I'd say your brake pads are worn to metal.
2- If the light looks like a broken circle that's the brake pad sensor telling you to replace the pads.
3- Look in the engine bay and underneath the car while its running. Maybe you have a leaking gas line.
1996 E36 M44 318i 5sp LSD
Canadian Model
RallyE36 is offline   Reply With Quote
Old 04-22-2005, 01:00 AM   #3 (permalink)
rear brakes were changed less half than a year ago....could it be CV joints or sumthing like that?
Old 04-22-2005, 01:08 AM   #4 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile
Send a message via ICQ to jrhaile Send a message via AIM to jrhaile Send a message via MSN to jrhaile
No. Check front brakes too? Also if the brake's were replaced but didn't have OEM sensor's replaced at the same time, it'll cause this to come on. Do your brakes feel/sound fine?
jrhaile is offline   Reply With Quote
Old 04-22-2005, 09:23 AM   #5 (permalink)
93 325i's Avatar
could be rear wheel bearing making that noise..
Complete mod list and pics:
My 1993 325i
Old 04-27-2005, 08:40 PM   #6 (permalink)
brakes arent totally smooth. its sorda jerky abit as i slow down....hmmmm how much do the oem sensors go for?
what do you suggest in trying to fix the noise from the rears? should i just change the brakes and the sensor?
Old 04-28-2005, 12:35 AM   #7 (permalink)
vincentwashere is an unknown quantity at this point
Send a message via AIM to vincentwashere
yeah its your brakes. if ur braking and its wobblin
if noise is coming from rear, could be your tires rubbing the fender, you should roll the fenders. if u havent
<img src='http://pic15.picturetrail.com/VOL615/2358567/4641837/67358906.jpg' border='0' alt='user posted image' />
vincentwashere is offline   Reply With Quote
Old 04-28-2005, 02:19 AM   #8 (permalink)
Retired administrator
triggrhaapi's Avatar
the mild gasoline smell when you start up is your catalytic converters taking a dump.
Addicted to Speed Since 1997
Bimmer n00b questions angryrobots 3-Series (E21, E30) 4 12-09-2007 11:08 PM
Couple of Questions rborak318iS 3-Series (E36) 5 10-02-2005 08:21 PM
Buying First Used Bmw, Have Some Questions ynotony 3-Series (E36) 1 06-06-2005 03:17 AM
New To Site, Have Some Questions Dj_325 3-Series (E21, E30) 6 05-12-2005 11:40 PM
Noob Questions.... 92_325i 3-Series (E36) 1 10-01-2004 11:16 AM
