| Help! Rusted retaining screw on rotors Hey,
So I decided to replace all my rotors and brakes since the current ones are completely worn out. I just bought the car and it had been sitting for almost a year at the previous owners house. I started with my front right wheel and everything went well except when i had to take out the rotor, and to do that i had to unscrew the retaining screw. I realized the screw was rusted so i sprayed some wd40 to loosen it up but it didn't do anything. after multiple tries i was not able to make the screw move at all. even worse the got stripped and now there is no grip on the screw. I am not sure what to do now. the screw has completely lost its inner grip and i am not able to do anything. i am stuck in the middle of the process and i need help. Also I tried to move to the back wheel and i am unable to unscrew the lug nuts. I have tried everything with manpower and i used my impact socket drill but still not a single lug nut moves. Please help, i really wanted to get this done. Thanks in advance
