Originally Posted by fmetaljacket If I’m cruising between 1600-2500rpm once in a while the car seems to forget that my foot’s on the gas this happens more often when i’m at the same speed or when i slow down. When it does this rpms drop down to idle (~700) and then it wakes up and goes back to where it was before but if I press on the gas before it gets to idle it will wake her up but the car gives a mean jerk when it wakes up. It happens alot at ~1700rpms but only if I slow down or keep the gas really steady if I'm accelerating it wont happen.
This problem really stumped me i don't want to throw any parts at her until i get a better idea of what's causing this... I've had a friend suggest the mass air flow sensor might be the problem or knock sensor. I’ve changed spark plugs and fuel filter with no success this week. I might be wrong but the car seems weaker than before i remember my head getting jerked back when accelerating. Any ideas?
Background:
1994 325i E36
Only happens between 1600 and 2500rmps
Happens in every gear even neutral
Car idles fine not erratic
Not affected by hot or cold weather or A/C |
I would say maybe a vacuum leak issue but if it idles fine, then maybe it's more of a fuel issue. test your fuel pump and pressure regulator. When was the last time you changed your fuel filter? Run some Sea Foam cleaner through your tank.
