Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 12-16-2003, 08:36 AM   #1 (permalink)
Photos: 0
macauto is an unknown quantity at this point
hey guys i need some help with this i have a 92 325i just replace the MAF sensor i tested the o2 and it has .45 voltage and it stalls after it warms up there are no vaccum leaks car idles rought but rmp meter dosent show any fluctuating any sugestions or ideas would be helpful thanks in advance
macauto is offline   Reply With Quote
Old 12-16-2003, 09:06 AM   #2 (permalink)
Idle Member
enemigo's Avatar
Photos: 0
enemigo is an unknown quantity at this point
dead o2 sensor?
BMW M3 '97
enemigo is offline   Reply With Quote
Old 12-16-2003, 09:54 AM   #3 (permalink)
Defector
El Presidente's Avatar
Photos: 0
could be an issue with a faulty fuel pump or injectors.
Old 12-16-2003, 06:06 PM   #4 (permalink)
Photos: 0
if it was injectors or pump wouldent it stall cold too not just when it was warmed up? thanks in advance guys
Old 12-16-2003, 06:36 PM   #5 (permalink)
Defector
Photos: 0
probably, but Im just throwing ideas out there. It might be that once the car has heated up there has been enough of a drop in fuel pressure that the car happens to shut off when the car is warm, not because the car is warm. Again, thats just my theory. Does the car restart after stalling or does it have to cool down first.
You should also do the pedal tap to retrive any fault codes, that might reveal your problem.
Old 01-24-2004, 03:11 PM   #6 (permalink)
Photos: 0
cgm451 is an unknown quantity at this point
Sounds like plugs and wires, work good cold and stalls warm. If the insulation on any of your plug wires is wearing thin (likely where 2 are rubbing together) they will short out when it heats up...goes for any car...how bout an update what was wrong.
cgm451 is offline   Reply With Quote
Old 01-24-2004, 04:31 PM   #7 (permalink)
TECH's Avatar
Photos: 0
e36, 325 does not have plug wires. You could have an idle valve sticking. You can try removing it and cleaning it, if you feel like diving in.
vB code is On
How To Tell Options With Vin? cm70man 5-Series (E12,E28, E34, E39, E60) 13 09-30-2008 01:23 AM
99 528i wad06 5-Series (E12,E28, E34, E39, E60) 5 12-11-2004 02:59 PM
Carfax Please: Wbadd632xwbw44671 cpuken 5-Series (E12,E28, E34, E39, E60) 3 12-03-2004 09:04 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
