help please!!! - BMW Forum - BimmerWerkz.com
Old 10-07-2008, 01:31 PM   #1 (permalink)
magicman420247 is on a distinguished road
help please!!!
i just got a 1992 325i with 149k miles and i want to change the oil i know how to do it i just dont know which brand and wieght would be the best
magicman420247 is offline   Reply With Quote
Old 10-07-2008, 02:24 PM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
As a general rule, always use a multi-grade oil that has the narrowest span of viscosity appropriate for your temperature zone . In the winter, base your decision on the lowest temperature you will encounter, and in the summer, the highest temperature you expect. Remember that oil with the fewest additives are the best, which is why synthetic oils perform better at a wider range of temperatures. 10W-40 and 5W-30 conventional oils require a lot of polymers to function properly at such a wide range of temperatures, leaving these two oils prone to thermal breakdown. You'll see very few experts recommending these two viscosities anymore, and even though 20W-50 has the same viscosity spread (30), it starts with a thicker base (20W) and requires less viscosity index improvers (polymers) to do the job. The synthetic oils on the market today offer superior high temperature oxidation resistance, high film strength, very low tendency to form deposits, stable viscosity base and low temperature flow characteristics. All of the conventional oils are good enough for most engines, but synthetics are superior lubricants to traditional petroleum oils. Synthetics can be run for two or three times the mileage of petroleum-based conventional oils, and they do not react to combustion and combustion by-products to the same level as conventional oils do.
There are many benefits of synthetic oils that most people do not understand, and because of their higher price, are unlikely to buy. Below are a few examples of such benefits:
Friction Reduction: This is all oils' main purposes to exist. It means a reduction in engine wear, which helps them last longer and require fewer repairs.
So go full Synthetic: 5w 30 or 10w 40 I run on 5w 30 in a V8 7 series.
