HELP! new E36 owner with electrical problems. - BMW Forum - BimmerWerkz.com
Old 04-30-2011, 08:14 AM   #1 (permalink)
Car: 92 318is
justin1180 is on a distinguished road
just got a 92 318is. this is my first bmw so i'm definitely having to learn. have some electrical issues that i've searched on. one i can't find anything about and the other there was no clear solution to the problem.
the most pressing issue that i have is that i have no brake lights. i currently have the switch unplugged because if you have it plugged in, as soon as you hit the brakes, it will blow the fuse and i lose my fuel and temp guages. i've seen at least one other person with the exact same issue but there was no solution posted.
the other is a window issue. both the driver and passenger windows will only roll up about an inch at a time. i didn't find any posts about this.
any solutions or links to at least the most pressing issue would be greatly appreciated.
thanks!
justin1180 is offline   Reply With Quote
Old 04-30-2011, 08:58 AM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
The live connection to the brake light wire has "Earthed" or "Shorted" to negative this is why it is blowing fuses...
You should chase the wiring from the fusebox to the pedal swith and back to the rear lights...
Hope this helps!
Old 04-30-2011, 10:17 AM   #3 (permalink)
Car: 92 318is
yes, that part i know. i just didn't know if there was a common area where the brake light circuit shorts.
Old 04-30-2011, 10:25 AM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
If the wiring seems ok then it could be the pedal switch itself....
Old 04-30-2011, 05:59 PM   #5 (permalink)
Car: 92 318is
SUCCESS!!
after about 45 minutes of isolating portions of the circuit and looking for broken wires, i found that the left lamp assembly was the culprit. there is a short in it causing it to take out the entire circuit.
Old 05-01-2011, 08:28 AM   #6 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Excellent result ;-)
Old 05-01-2011, 11:05 AM   #7 (permalink)
jimmythepie's Avatar
Car: 98,328i
Dabs,your a welcome noob. You should go far here,we need someone like you since the resy of the guys went AWOL.
jimmythepie is offline   Reply With Quote
Old 05-02-2011, 12:41 PM   #8 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Thx Jimmy... Here to stay, mate !!!
As for the elec windows prob as mentioned... It could be the EWS module at fault as I have a similar issue with my sunroof !!!
DAZ
Old 05-02-2011, 12:43 PM   #9 (permalink)
Car: 92 318is
thanks dabsy. i'll check that out
E36 electrical problems avidco 3-Series (E36) 3 12-12-2007 06:33 PM
Electrical problems jrsbmw 3-Series (E21, E30) 5 02-08-2007 09:12 PM
Electrical Problems Duge 3-Series (E36) 12 04-30-2005 05:41 PM
Electrical Problems Ecu? jmurch 3-Series (E46, E90) 1 01-11-2005 01:18 PM
Electrical problems Hamann 325i 3-Series (E36) 0 10-06-2003 09:42 AM
