Help! My a/c will not turn on! - BMW Forum - BimmerWerkz.com
Old 05-26-2004, 02:30 PM   #1 (permalink)
jroberts312 is an unknown quantity at this point
My ac started acting up yesterday. It first started by me trying to turn it on. It did nothing. I tried pushing other buttons and it started. I thought it was just a fluke. Then it happened again but took even longer to start. The symptoms are not display on ac panel. Nothing at all. Now it will not start for nothing. I checked all fuses and relays. I looked in service manual for the relays related to ac. There were two, one for heater/ac and the other for compressor. I swapped with another like relay and it still would not turn on. Does anyone know what it might be? One other symptom is the display turned on but then shut off with some led's still lit up. Help! It will be a hot summer.
jroberts312 is offline   Reply With Quote
Old 05-26-2004, 03:28 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
you could be out of freeon. check your auxilury fan to make sure its not stuck or somewhat restricted in movement. lastly if all else fails you could be looking at an expensive fix (could be a faulty compressor or an electrical problem in the climate
Old 05-28-2004, 09:26 AM   #3 (permalink)
Hey found a fix. Tried it and it works great.
http://www.macadamizer.com/bmwfix.html
Old 05-28-2004, 10:37 AM   #4 (permalink)
When you say it isn't working, do you mean the air isn't cold or there isn't any air at all?
Go to a shop and ask them to check out the freon. If it's gone tell them to top it off and then check for leaks. I paid around $60-$70CDN for them to top it off. According to my mechanic mine isn't leaking. Yet I have to top off every 2 years. Strange.
Bry
Old 05-28-2004, 10:46 AM   #5 (permalink)
You must not have read my previous post. It is working now. The symptoms were that the air would not turn on at all. The ac control was broken. Not led display at all. Sometimes it would turn on and shut off. Some leds would remain on but no air. Works now. I am happy.
Old 05-28-2004, 11:06 AM   #6 (permalink)
infared21 is an unknown quantity at this point
Send a message via AIM to infared21
I had this same problem when I first got my car.. it worked when it wanted to. It is really an expensive fix, forgot what they did actually.. ill see if i can find the service report.
<img src='http://infared-designs.com/misc/bmw328.jpg' border='0' alt='user posted image' />
infared21 is offline   Reply With Quote
Old 05-28-2004, 01:46 PM   #7 (permalink)
fushuman is an unknown quantity at this point
Well i dunno what's wrong with my car.
The fan seems to work at any speed and temp. seems ok as well. But the problem is it just comes out from the bottom (towards my feet). I've pressed every single button on the Climate Control, but no air comes from the front or defroster or defogger ghead
Maybe is somw kind of fuse thats burned or something, i just dunno
<img src='http://www.bmw-forums.com/forum/uploads/photo-7050.jpg' border='0' alt='user posted image' />
CONQUER THE WORLD WITH YOUR <span style='color:red'>HEART</span>!!!!!
CONQUER THE RACE WITH YOUR <span style='color:blue'>SOUL</span>!!!!
fushuman is offline   Reply With Quote
Old 05-28-2004, 03:30 PM   #8 (permalink)
Jamesr316 is an unknown quantity at this point
AC sucks in german cars. Always has, probably always will. Guess you dont really need AC when your going 100 on the autobahn...
Jamesr316 is offline   Reply With Quote
turn signals not working ganjacyde 3-Series (E36) 3 05-25-2012 09:28 AM
My Abs Light Came On!? Help! Delmarco 3-Series (E36) 3 07-02-2005 08:48 PM
Turn Off This Airbag Light....help! Sickblack328 3-Series (E36) 6 06-28-2005 06:59 PM
HELP! Turn Signal not working??? kraze0g 3-Series (E36) 7 06-22-2004 12:39 PM
Interior lights will not turn off Wurzig-Drei 5-Series (E12,E28, E34, E39, E60) 2 02-02-2004 09:22 PM
