Originally Posted by sim2101 is the fuel filter something i can fit?? Where is it?? and where do you get maf sensor cleaner from as i have looked on ebay and cant find any, thanks |
well any auto parts store will sell maf sensor cleaner autozone advanced auto parts. as far as changing your fuel filters its on the under body heres a pic and diagrame with intructionsThe fuel filter is located on the left side front frame rail. A set of fuel line block off clamps are needed for this procedure. They are available at most automotive parts stores at reasonable prices.
Install the fuel line block off clamps on both the inlet and outlet lines to the fuel filter. This will prevent fuel from leaking out of the hoses once the filter is removed.
Loosen the fuel line clamps. Use a container to catch the fuel left in the filter and remove the hoses from the filter, top hose first.
Remove the filter by loosening the clamp bolt and prying the clamp apart.
To install:
Note the direction of flow of the new filter and install the filter. Tighten the clamp bolt.
Attach the fuel lines to the correct ends of the filter and tighten the hose clamps.
Check the area for leaks.
E36 325i AND 325iS
See Figure 1
