Help: Loud Whistling Sound On E36b - BMW Forum - BimmerWerkz.com
Old 12-04-2004, 10:11 AM   #1 (permalink)
oe_tuning is an unknown quantity at this point
hi...
I look into a used 320i M52 today.
The engine looks fine except the following problem:
It has a really really loud whistling noise when the engine is running.
It was quite 1st time we start it up, but after it warm up then the whistling sound came...even while we drove it.
The sound was so loud that we can even hear it with the hood closed and in a busy street!!!
any idea what the problem is guys??
Also, what is top overhaul?
should I consider buying a beemer that already has top overhaul ?
Thx!!
oe_tuning is offline   Reply With Quote
Old 12-05-2004, 02:18 AM   #2 (permalink)
anybody???
Old 12-05-2004, 11:54 AM   #3 (permalink)
abemcclellan's Avatar
abemcclellan is an unknown quantity at this point
my guess is that it could be one of your pullies making that whinning sound.
abemcclellan is offline   Reply With Quote
Old 12-05-2004, 11:55 AM   #4 (permalink)
how does it run when you hear this noise?
Old 12-05-2004, 12:27 PM   #5 (permalink)
TMac325is's Avatar
you may just be hearing the fan in the front of the car, all e36s have those noisy fans, but if its extremely loud and obnoxious its definately not the fan
Old 12-05-2004, 12:34 PM   #6 (permalink)
YoungExec728 is an unknown quantity at this point
The pulleys might be torqued down too tight, that happened to a friend after we installed his undrive pulleys. Maybe be the belts too???
<img src='http://memimage.cardomain.net/member_images/9/web/741000-741999/741934_9_full.jpg' border='0' alt='user posted image' />
JC Chip * Cosmos Racing CAI * UUC System U * UUC Underdrive Pulleys * Fan Delete * UUC Sachs Stage 4 Suspension * Sway Barbarians * Racing Dynamics Front strut bar * X-Brace * Front Camber Plates * UUC TME * BBS 18x8.5 * 235/40/18 Yokohama AVS Sport * F&amp;R Zimmerman X-Drilled Rotors * SS Brake Lines * Rouge RSM w/enforcers * Clears all around * SilverStars * Pioneer Avic N-1 * Pioneer 6 Disc Changer * JL 450/4 and 1000/1 Amplifiers * 2 JL 12&quot; W6V2 * Diamond Audio Hexs 6.5&quot; in kick panel * MB Quart Premiums 4&quot; in Rear * Infinity Kappa 3.5&quot; in door * Batcap 400 * Optima Yellow Top
YoungExec728 is offline   Reply With Quote
Old 12-05-2004, 03:12 PM   #7 (permalink)
RedlinedRU's Avatar
RedlinedRU is an unknown quantity at this point
Send a message via AIM to RedlinedRU
That could be possible because a warm engine will have slightly more tension on the belts than a cold one because of expansion. But on the other hand, the belt will become more elastic as its temperature rises.
<span style='color:green'>
AMG can't build an NA engine that can compete with M engines, so they stick in a supercharger and say their cars are faster. BMW could simply do the same, but they don't out of principle.</span>
RedlinedRU is offline   Reply With Quote
Old 12-06-2004, 12:45 AM   #8 (permalink)
Sagas's Avatar
Car: 94' 325iA
Sagas is an unknown quantity at this point
Had a similar problem with mine, replaced the upper drive pulley and no more howling.
Sagas is offline   Reply With Quote
Old 12-06-2004, 04:21 AM   #9 (permalink)
[snapback]244298[/snapback]
Thx for all your suggestions.
I'll check on the pulleys right away
The dealer dod mention about some cover having a hole and that the air passing through that hole is making a noise.
But I was not clear on wich cover he meant.
Another thing, is it safe to buy a beemer that already has a top overhaul?
Loud Whistling Noise In Engine morristhecoolcat 3-Series (E36) 0 05-11-2005 02:54 PM
Strange Sound Under Car Henri 3-Series (E36) 16 04-06-2005 03:26 PM
help the sound of my 318i mikester328 3-Series (E36) 1 09-20-2004 08:34 PM
Loud exhaust sound at 20 or 25 mph koolkat1973 M-Series (M1, M3, M5, M6) 2 08-14-2004 08:36 PM
whistling sound from back sanai79 3-Series (E46, E90) 2 04-27-2004 12:38 PM
