Sounds to me like there is something throwing an error still. You'll have to go through the fault codes and find what's throwing the error. You can find the fault codes
here.
Hopefully it's something simple...just find the fault...repair...reset the CEL with the described DIY.
You could also try the solution SHAHAB323IS described above.
